Ubs55 bighorn
avengertiger
The wife melted the fuse for indicators and now I have none pretty sure I found the fault on the trailor plug but need to get them working again to sort it.got the melted fuse out and still have power at fuse,I have a shitload of relays to figure out anyone on here know where the turn signal relay is located?
Have found the headlight relays on inner guard and one under the expansion bottle on passenger side.i have no hazards or fan blower either.
Can't seem to find a wiring diagram online have searched all the itoc sites with no luck.if I can rule out the relay I can start on wiring.
Thanks in advance
Cheers yep have checked all the usual spots,no relays on drivers side footwell there is a relay on the side off the blower unit with the speed controller for fan but presume that is for the fan.
The ones in the fuse board are all labelled on the fuse cover for alternator,ac condenser etc the four I found on inner guard seem to be for dip lights,head lights and main beam.
Will have to find me a proper workshop manual.
Thanks
