bugn8r Posted October 15, 2013 Share Posted October 15, 2013 Hi all, Just bought a Chevette and want to lower it a bit, not slammed but just to have it sitting better. I can get a full set of Holden Gemini springs for $100, is it worth it and do they fit? I remember reading somewhere that they do. Any help would be sweet Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted October 15, 2013 Share Posted October 15, 2013 Gemini fronts fit with the rears I know Gemini wagon and sedans are different length wagon ones are shorter I think so wagon rears in a sedan would make the rear lower than the front not sure about a hatch tho. Quote Link to comment Share on other sites More sharing options...
CUL8R Posted October 15, 2013 Share Posted October 15, 2013 Gemini lowering springs should work - as in they will fit in. However Im not sure how much the front will come down by... 1600 gemini 1300 chevette, although the chevette's is a full cast iron block the gemini motor & box is about half as big again.. What area are you? 1 Quote Link to comment Share on other sites More sharing options...
bugn8r Posted October 15, 2013 Author Share Posted October 15, 2013 I'm in Welly for uni until mid November then back to Chch where the car is. Are there many of the Geminis around. I did a quick search on trademe and could only find a sedan which the guy said I could have the springs out of for $100 bucks. Quote Link to comment Share on other sites More sharing options...
CUL8R Posted October 16, 2013 Share Posted October 16, 2013 Not a huge amount, although I have both a Chevette and gemini in my garage lol... http://nzgem.proboards.com/index.cgi Join up here, Im sure someone will have some standard height springs. Quote Link to comment Share on other sites More sharing options...
mikuni Posted October 16, 2013 Share Posted October 16, 2013 Are they standard Gemini springs? I would say they would lift the Chevette up quite a bit and you may even have trouble getting them into the front wishbones in full length. Probably best to hunt out a set of lowering springs for it. Torana super lows fit the front and make it quite low, and in the back Gemini wagon springs will work, but you might want to take a little bit off them and run shorter shocks to keep them captive. Quote Link to comment Share on other sites More sharing options...
CUL8R Posted October 16, 2013 Share Posted October 16, 2013 Hey actually, I'll have a Piazza in a couple of weeks... I could possibly lend a hand to install them if you wanted (read: cut them) . Whats wrong with yours? Quote Link to comment Share on other sites More sharing options...
bugn8r Posted October 16, 2013 Author Share Posted October 16, 2013 The car only has 56,000 k's and is mint so wanted to be able to chuck it back to stock. Might start a thread for it Quote Link to comment Share on other sites More sharing options...
bugn8r Posted October 16, 2013 Author Share Posted October 16, 2013 Does that photo work for you guys? Quote Link to comment Share on other sites More sharing options...
bugn8r Posted October 16, 2013 Author Share Posted October 16, 2013 Cheers by the way Quote Link to comment Share on other sites More sharing options...
Taistorm Posted October 16, 2013 Share Posted October 16, 2013 Cobra springs from Chamberlains in ChCh will drop the front about 30mm and rear about 40mm. Theyre about $150 a pair from memory. I ran slightly shorter get reflex shocks on mine but should still be captive with the standard shocks. Quote Link to comment Share on other sites More sharing options...
bugn8r Posted October 16, 2013 Author Share Posted October 16, 2013 Cheers man, will investigate Quote Link to comment Share on other sites More sharing options...
