junglesponge Posted September 7, 2013 Posted September 7, 2013 Hey ive got a 1300 x flow engine in a mk2 cortina and i have a faulty generator.my parts man said it was hard to get a good replacement one so wanted to know what was required in hooking up a alternator.do i need to add any wires/remove any wires to connect this successfully?what car should i look at getting one from? Quote
fourfingapete Posted September 7, 2013 Posted September 7, 2013 I just did my Vauxhall. Hardest part was making up the brackets and lining up the pulleys. I used a bosch out of a polo. Basically only 3 wires out (2 power and 1 for alt light) I used this tut for guidance.http://www.mgccars.com/gen-to-alt-conversion.html 1 Quote
junglesponge Posted September 7, 2013 Author Posted September 7, 2013 thanks guys thats awesome just the info i needed Quote
Ghostchips Posted September 7, 2013 Posted September 7, 2013 Lucas alternator, old school kind. On big wire to battery, the other little wire to the dash light which goes to the switch & from the switch the fuse box if i remember correctly. Quote
Beaver Posted September 7, 2013 Posted September 7, 2013 //oldschool.co.nz/index.php?/topic/27727-escort-dynamo-alternator-conversion/ have a look through this, it sme helping a guy out doing the same thing, and there is a link to the article I used near the bottom (think tis the same as the one someone posted earlier). I did it in a mk2 cortina as well and was super simple. best of luck! Quote
