larsenz Posted January 10, 2013 Share Posted January 10, 2013 sorry for the other post about the gearbox, i didnt get a chance to have a good look. was driving home from rhythm and vines, when shit hit the fan. theres oil every where even on the brakes so i have decided to get a whole rear end. if anyone has any ideas on an affordable upgrade or replacement all help is appreciated. by the way it has a 4age with a t50 box so i am maybe thinking a t series rear end with drum brakes?? thanks.! Quote Link to comment Share on other sites More sharing options...
ae85 fiend Posted January 10, 2013 Share Posted January 10, 2013 How complete are you looking for? I got a ke36 diff - its in storage though, wouldn't be able to get to it till another fortnight or so, but I also have a ta22 rear end at home, got axles, no head ( I do have one, 4.1:1 but needs a new bearing? In it - thats what my mechanic said when he swapped it out for my 4.8 ) which i'll throw in as well if your keen. The ta22 diff has no brakes, so you'd need to sus that out, no handbrake cables, but i just used my ke35 ones and it works. Quote Link to comment Share on other sites More sharing options...
Bling Posted January 10, 2013 Share Posted January 10, 2013 What exactly is broken in your current diff? I'd work that out first, and find out how much it will cost to fix / replace the parts. If you plan on giving the car a hard time though perhaps an upgraded diff would be the go. Quote Link to comment Share on other sites More sharing options...
evil_si Posted January 10, 2013 Share Posted January 10, 2013 Is your current diff ok apart from the oil leak? Axle seals are cheap and relatively easy Quote Link to comment Share on other sites More sharing options...
larsenz Posted January 10, 2013 Author Share Posted January 10, 2013 na its not just the oil leak, im guessing its completely stuffed as there is a real noisy grinding noise constantly, and its spitting out alot of oil. like 100mls a day or more. keen to upgrade to something stronger. can u get a t series diff with drum brakes? Quote Link to comment Share on other sites More sharing options...
ae85 fiend Posted January 14, 2013 Share Posted January 14, 2013 Yeah dude, ta22 diffs are drum, some of the T series te71 diffs are also drum? Be careful when looking at those, might end up with a S series instead. I believe most of the corona t series are all drums aren't they? Quote Link to comment Share on other sites More sharing options...
