mikey Posted October 14, 2012 Share Posted October 14, 2012 I'm pissing about trying to find a oil pressure sender that'll work with the stock gauges. I think an RB one will work. However, during this pissing about I took the sender out of the engine and cranked it over expecting to see oil spit out the hole. But only saw a few ml ooze out after cranking it over about 10-15 times. Is that normal at cranking speed or should I be seeing more of an ejaculation of oil? Quote Link to comment Share on other sites More sharing options...
peteretep Posted October 14, 2012 Share Posted October 14, 2012 on my escort engine the line running from the high pressure line to the low pressure sender is only a few mm diameter so it seems reasonable that not much oil would come out during cranking, my escort also did not get big oil pressure during cranking though Quote Link to comment Share on other sites More sharing options...
projectr30 Posted October 14, 2012 Share Posted October 14, 2012 sounds normal to me, no rpm = no oil pressure and cranking speed is not much rpm. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted October 14, 2012 Share Posted October 14, 2012 I was a little conserned coming in here right before lunch but it seems ok Quote Link to comment Share on other sites More sharing options...
