Beaver Posted November 11, 2012 Author Share Posted November 11, 2012 planning on taking this up to the coromandel for xmas/new years so am just ticking off a few things that need doing to make the trip more enjoyable/sucsessfull. Manual swap will have to wait till the new year me thinks, will give time to grab a a15 and do it all at once. First job was to sort out rubbing in the back. Gave the worst side a quick runover with the hammer and that solved it (so I thought). turns out with three people in the car its a different story..... Gave them another working today, should to the trick. Just used a mallet and was pretty tidy. One guard had had rust repairs done in the past so had some filler in there, is messy underneath but you cant tell uess you stick your head under the guard. that is all Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 8, 2013 Author Share Posted January 8, 2013 Right quick update. Just got back from trip away for christmas and new years etc. Day before we left the carb started pissing petrol everywhere and I suspect it was a jammed float (I figured this out afterwards mind you), so had a rather frantic night in the shed stripping, cleaning and reassembling carb. Long story short, ticked up over 2000kms over a couple of weeks, with only a couple of hickups (my fault). Had so many piners along the way so it all makes up for it. (boot/backseat is loaded with shit hence gay rake....) Wof is due March so have a few things to sort out for that (found some rust, and need to get front springs captive/shorten shocks). Will then look at aquiring a15 and manual gear. Discussion http://oldschool.co....e/page__st__120 Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 26, 2013 Author Share Posted January 26, 2013 Doing some things Ive been meaning to do for a while and also geting things sorted for a WOF. Front struts are out, need to get 20mm taken off inserts (unfortnatly the original oil filled gear has been replaced). Replaced sway bar linkend bushes with new nolothane (what a ripoff....) Dummied up chin spoiler, needs some tweaking. New oil filter and oil change Diff oil change //oldschool.co.nz/index.php?/topic/33955-beavers-wuntwennywhy-coupe/page__st__120 Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 28, 2013 Author Share Posted January 28, 2013 chin spoiler all mounted up, looks tough. had to trim a bit out of the length but pretty good fit considering its mad for a mk2 golf (I think). Talked to autolign, will take my shocks into them to get shortened (50 bucks each but meh, save sthe hassle of tryign to get a local engineering place to do it), hopefully take them in tomorrow and will be ready next week. Then everyhting is ready to go back together and should be all legit for a wof at current hieght/appearance etc Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 5, 2013 Author Share Posted February 5, 2013 Back together again had the shocks shortened to suit the springs and did some stuff I knew it needed for WOF next month. needs more low.....and I need to paint the door/window frames black like this one, discuss //oldschool.co.nz/index.php?showtopic=33955 Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 17, 2013 Author Share Posted February 17, 2013 mmmmm polished fiins Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 20, 2013 Author Share Posted February 20, 2013 spot the difference..... big thanks to KK for getting some vinyl and doing most of the hard work Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 24, 2013 Author Share Posted February 24, 2013 Engine has starting pissing oil and coolant on the floor..... Looks like most of the oil is coming from the valve cover seal so will replace that, and the oil pressure swich has been leaking for a while so will get a new on as well. Coolant is strange though, its hitting the floor near the back of the motor, no obvious leaks, and seems to be dripping from the bottom front engine of the gbox. Thought for a bit that maybe it was a BHG but oil change a few weeks ago showed no water/coolant. Possible that there is a frost plug on the back of the motor (within the area hidden by the belhousing)? Doesnt use "much" oil and water just needs a small top up occasionally so not really concerned, its just messy as fuck haha Quote Link to comment Share on other sites More sharing options...
Guest Beaver Posted March 17, 2013 Share Posted March 17, 2013 WOF achieved, nothing major, new muffler was the worst. Carb shat itself today, has done it before and couldnt be bothered pissing about with it so swapped it for another I had, worked a treat. Have bid on an a15....cant affored it but worth a shot haha. Bring on Nats! 1 Quote Link to comment Share on other sites More sharing options...
Guest Beaver Posted April 16, 2013 Share Posted April 16, 2013 Survived nats (well car did, my body is stil revovering....) After seeign the calibre of cars on hand, Ive decided it is too slow and needs more low..... 4 Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 26, 2013 Author Share Posted April 26, 2013 Well the car hasnt left the garage since nats....still covered in shit haha Although have been piecing bits together for manual swap, only driveshaft left to go then will pull motor and box out and give in a whirl. Will likely have to come up with something for the gbox xmember as the interwebs tells me the manual one wont bolt in. Can either make some adaptor plates or make another xmember. Also need to check out a suspect frost plug and replace if required, Where does one get frost plugs from? Also Fly wheel bolts, I assume I should get new ones? Do I need special ones or just some grunty high tensile ones from the nuts and bolts shop? discuss //oldschool.co.nz/index.php?/topic/33955-beavers-wuntwennywhy-coupe/page__st__160 Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 29, 2013 Author Share Posted April 29, 2013 Right, motivation levels are high. Have everythign I need for manual swap except driveshaft (have a few leads workign on it for me however). There is a high chance I will need to make up some adaptor pates for the gbox x-member although no biggy. Also picked up a set of bike crabs from Denham, should be a bit of fun. I think i will have to run extractors (what a shame...) with these as the facotry intake and exhaust manifolds are botled together with a little flap inbetween so wont really work. (well I could make a up a blanking plate and bolt it on.....but is a good excuse for a nicer exhaust I guess) Onwards! 1 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 1, 2013 Author Share Posted May 1, 2013 Yay for bike carbsm cheers Denham! Also trimed down the third bumpstop (above the diffhead) Before During After discussion //oldschool.co.nz/index.php?/topic/33955-beavers-wuntwennywhy-coupe/page__st__200 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 25, 2013 Author Share Posted May 25, 2013 I have a clutch pedal! shame it doesnt do anything. Swaped out pedal boxes today and replaced firewall blanking plate with clutch cable guide thingy. Looking to pull motor and box out over the long weekend and will see how things go, hopefully get it all back together again as well. 3 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 26, 2013 Author Share Posted May 26, 2013 More progress!! 3 pedals! Bonnet off Radiator out, everything disconnected from engine Auto shifter etc out Current sate of affairs/state of chaos in the shed Need to get my axles stands back of Joe (cough cough) so I can get it off the ground then pull out driveshaft etc and disconect shit from gbox (speedo cable, wiring, vacuum shit). Then grab engine crane from the mighty vivaspeed and rip that bitch out. Repco was having a sale today (25% of shit, including oil) so though of stocking up on that for the swap but Im too lazy. I think (famous last words....) I have everything I needs, the only think I know needs doing it modifying or making an adaptor for the cross member. Will line shit up and take it from there. Discussion //oldschool.co.nz/index.php?/topic/33955-beavers-wuntwennywhy-coupe/page-11 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 26, 2013 Author Share Posted May 26, 2013 woops, also just brought another set of bike carbs.....although they come with a manifold and are set up for an a12 so should be good to go! 2 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 28, 2013 Author Share Posted May 28, 2013 mmmm carbs 2 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 28, 2013 Author Share Posted May 28, 2013 bit more progress tonight mocked up carbs on a spare head, fit perfect! pulled intake and exhaust off to aid engine removal. also got rid of any excuse for sticking it back together with original carb for start up.... nice to see engine has had a once over at some stage (old owner mentioned this I think) and couldn't help myself discussion //oldschool.co.nz/index.php?/topic/33955-beavers-wuntwennywhy-coupe/page-11 Also if anyone in Welly wants to stand around and talk smack and have some beers then welcome to drop by this weekend, ill be ripping the engine and shit out and hopfully getting all the manual shit back in 4 Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 31, 2013 Author Share Posted May 31, 2013 more progres! Big thanks to KK for helping out/telling me what to do and Shaz for yelling abuse Pulled engine and box out. Took off auto and associated crap. Located fucked frost plug in back of block, ripped out. Engine shat all over the bench. yum yum Tomorrow, clean engine bay, clean motor, flush block good and proper, and fingers crossed Repco will have a plug for me. Pic dump. (All out of order, fuck it) discussion //oldschool.co.nz/index.php?/topic/33955-beavers-wuntwennywhy-coupe/page-11 Quote Link to comment Share on other sites More sharing options...
Beaver Posted June 2, 2013 Author Share Posted June 2, 2013 spent another few hours in the shed (again, huuuuuge thanks to KK)Cleaned engine bay and motor Replaced frost plug Put shit together Put in the hole And carbs on to keep up motivation Need to get some extractors (factory exhaust manfoold is gay and has an open port which bolts to factory intake which is now in the bin)Need to get longer throttle cable to reach new carbs (Bike cable should work)Need to make up litle adaptors for gbox xmember. Have this sussed out so pretty straight forward.Then fill everything back up with fluids and (try) do a skid discussion //oldschool.co.nz/index.php?/topic/33955-beavers-wuntwennywhy-coupe/page-11 3 Quote Link to comment Share on other sites More sharing options...
