Sambo Posted August 11, 2012 Share Posted August 11, 2012 The 1S-U in my SA60 is getting sicker and sicker, runs very low oil pressure etc etc. I have a spare 1S that I was thinking of freshening up but then I started whether I should throw a 2S engine in instead (2000cc vs current 1800). I've been on wikipedia, which tells me that my 1S makes (made) 74kw and 152 N·m of torques. An Aussie 2S-C makes 73kw and 157 N·m. Does anyone know these engines well enough to tell me why 200cc more makes less power and only slightly more torque? Bore is increased by 3.5mm and stroke remains the same at 90mm. I also know that 2S-C has awful stuff like an airpump to put more fresh air into the exhaust to reduce emission readings. Could I use a 1S head and 2S block? 1 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted August 11, 2012 Share Posted August 11, 2012 prolly cant use 1s head with 2s bottom end sue to piston size vs combustion chamber. Air pump is probably robbing a few hp's and if its got emissions shit it will be holding the engine back most likely (not that it would be a powerhouse) Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 12, 2012 Share Posted August 12, 2012 1S's actually go OK, just find a fresher one and bang it in. I wouldnt waste much money on pulling them appart Quote Link to comment Share on other sites More sharing options...
Simon Posted August 12, 2012 Share Posted August 12, 2012 I have a good 1s here you can have for $100. From an auto car. Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 12, 2012 Share Posted August 12, 2012 Do that Quote Link to comment Share on other sites More sharing options...
Sambo Posted August 12, 2012 Author Share Posted August 12, 2012 Gc. Will be in touch. I wasn't that keen to open one up, this is just to keep it reliable until 3sge swap, roman style Quote Link to comment Share on other sites More sharing options...
