felixx Posted December 16, 2011 Share Posted December 16, 2011 Shouldnt be too tricky should it? Loosen fan belt Unbolt alt unplug wires plug wires onto new alt bolt in tighten fan belt Have I missed anything? Quote Link to comment Share on other sites More sharing options...
Ranter Posted December 16, 2011 Share Posted December 16, 2011 Disconnect battery. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 16, 2011 Share Posted December 16, 2011 ^ this Easy to forget. Some have a wire that is bolted on. When installing you'll need a lever to tension up the alternator as you tighten it. I have only ever gone for a 'licked finger in the air' type of tension measurement and have been fine so far (when I have had non-dud alternators) Quote Link to comment Share on other sites More sharing options...
