shizzl Posted March 7, 2011 Share Posted March 7, 2011 does anyone know if a 3.8 v6 will go into a hj holden without too many issues?? would like to steer clear of cutting the tunnel and sump.... will use a t5 manual from a vn Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 7, 2011 Share Posted March 7, 2011 Shouldn't need to cut the body, the sump will need work though. These guys do mounts etc http://www.rodshop.com.au/holden/hq-wb.htm Quote Link to comment Share on other sites More sharing options...
Jase Posted March 7, 2011 Share Posted March 7, 2011 it'll fit for sure, can't remember if rear sumping is required (possibly is) throwing the diff and brakes in too would be a good upgrade Quote Link to comment Share on other sites More sharing options...
insanebrain Posted March 8, 2011 Share Posted March 8, 2011 One of the issues of Australian Muscle Car actually covered this swap a couple of years back. Sorry I cant check which one/scan it for you as I am in the wrong island for a while (collection south, me north) Quote Link to comment Share on other sites More sharing options...
shizzl Posted March 8, 2011 Author Share Posted March 8, 2011 i doubt that vn brakes would be bolt on would they? ;p i should chuck the vn diff in too..but im not after a big mission.. just something fairly simple. my v6 turned up today.... will be a mean v6 carby motor..will put a 4 barrel on it.. get the loom and ecu modded if i can find someone to do it.. Quote Link to comment Share on other sites More sharing options...
shizzl Posted March 8, 2011 Author Share Posted March 8, 2011 stumbled across this http://oldholden.com/node/31769 Quote Link to comment Share on other sites More sharing options...
shizzl Posted March 8, 2011 Author Share Posted March 8, 2011 also http://www.oldholdens.com/forum/viewtopic.php?f=5&t=51 Quote Link to comment Share on other sites More sharing options...
shizzl Posted March 8, 2011 Author Share Posted March 8, 2011 ok, found a pearler!!! amazing what you can find when you search through unrelated crap http://members.ozemail.com.au/~brettsue ... /index.htm Quote Link to comment Share on other sites More sharing options...
Jase Posted March 8, 2011 Share Posted March 8, 2011 would stick to efi chap, just get the manifold modded to run the throttle body upright, then slam and old looking filter on the thing Quote Link to comment Share on other sites More sharing options...
EFI_LC Posted March 8, 2011 Share Posted March 8, 2011 The V6 is a narrow beast and should fit without much drama and being a 6 the weight distribution is good as it can sit well back. Brakes are usually easy to fit although I dunno if its much of an upgrade Quote Link to comment Share on other sites More sharing options...
shizzl Posted March 8, 2011 Author Share Posted March 8, 2011 how cunty is the injection/ecu to wire up?? Quote Link to comment Share on other sites More sharing options...
EFI_LC Posted March 8, 2011 Share Posted March 8, 2011 how cunty is the injection/ecu to wire up?? You could do what I did when I threw an Injected motor in my LC. I went to the library and photocopied the wiring diagram. Then I removed all wires I didnt need and labeled all the others as much as I could I then connected them all up and found only had a couple to sort out which I went to an auto-sparky shop and they told me how to do them. One at a time and before you know it its done The main difference with brakes is the vented discs need a bit more clearance but all the older holdens use the same wheel bearings so no problems with stub axles. Easy enough to pull the H off to try the V. Quote Link to comment Share on other sites More sharing options...
Jase Posted March 9, 2011 Share Posted March 9, 2011 3 wires to the ecu chap, power,earth and relay from igniton to pink wire, pretty damn simple really even i'm giving mine a go when i get to it, local library will have a haynes to copy the wiring diagram from Quote Link to comment Share on other sites More sharing options...
shizzl Posted March 9, 2011 Author Share Posted March 9, 2011 is that it, just to get it to run? obviously theres other wires for tacho etc yeah? choice..... oh, what about fuel pump wire?? Quote Link to comment Share on other sites More sharing options...
Jase Posted March 9, 2011 Share Posted March 9, 2011 runs off ignition-(vl fuel pump will do), gauges etc can use manual or electronic speedo, pulse wire from the computer should fire an aftermarket tacho, just get the diagram and nut it out from there. I'll be spending the coin and buying some nice period gauges and trying to use my original speed with a different drive gear in the box. Quote Link to comment Share on other sites More sharing options...
EFI_LC Posted March 9, 2011 Share Posted March 9, 2011 you also need to run a new fuel line as injection needs a return line, I used the original line to feed the injection then used low pressure return line. Also check after installation as you will most likely find you only have 9volts at the coil which will reduce to 7 with revs, this is easy enough to run a new feed via the key. Also by using a small fuse box it may save you from a rewire job if there is a short anywhere. Quote Link to comment Share on other sites More sharing options...
