Beaver Posted March 30, 2011 Author Share Posted March 30, 2011 so pulled the rear end to bits to inspect all the bushes and shit. didnt find anything majorly fucked but have some new bushes on the way anyway. rear d/shaft UJ was farily graunchy so orderd a new one of those as well. then I decided it would be rude not to see how it sits while the springs were out....... then I realised I hadnt put the d/shaft back in and the gearbox was doing wees all over the floor....woops. can I just top it up/fill it up through the shifter hole? or will I have to get intimate and fill it from the underside? discussion viewtopic.php?f=18&t=25248 Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 2, 2011 Author Share Posted April 2, 2011 long story short, got upgraded from some shitty hankooks to some lush toyo proxes for only 10buks extra, ended up at $123 a pop fitted and balanced. so chucked them on this morning. needs a bit more low, bout 40mm or so. cut front bumps in half and theres f all travel left so that could be interesting....back will be easy, plenty of room and plenty of bump stop to cut off. also painted rocker cover. current sits liek this, has no oil in the gbox due to me being a muppet rear tyres rubbed when I had no springs in my only just, so a bit of lip vs hammer action will solve that. Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 3, 2011 Author Share Posted April 3, 2011 had another go at removing the body strips, paint work underneath is damaged/discolored due to the glue so it looks like they will have to stay Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 7, 2011 Share Posted April 7, 2011 At beave's request... Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 9, 2011 Author Share Posted April 9, 2011 also quickly repainted the black inserts on the wheels as they were flaky and shit, was a cunt to mask up and spray so just did it with a brush lol before after discuss! viewtopic.php?f=18&t=25248&start=160 Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 10, 2011 Author Share Posted April 10, 2011 Some sharp eyes may notice in that last pic of the wheel it looks hideously bent.....well it is lol. seems to run alright though, only a little bit of vubration through the steering wheel Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 30, 2011 Author Share Posted April 30, 2011 quick update, not ont he car though haha, went to the tip shop today and got a table and some shelves for 15 buks. tidied up the garage and now have space! can even get the middys car in there. on the car front, still having carb issues, should be sorted for ats. it drives, just misses and coughs at times so il be there regardless. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 17, 2011 Author Share Posted May 17, 2011 Right, have digged deeper into the misfire I was getting. slapped on another carb, got it running, still random misfire. Upon further prodding, Joe/goat/flange and myself foudn that the number 3 cylinder wasnt firing at idle but seemed to fire once the engine was doing a few revs. so we figured the mis was this cylinder dropping out/firing out the carb (it sounds like tis coming out the carb). new plugs, different leads, different cap, didnt make any difference. so tonights job is to check compression (assuming repco has a cheap one when I go there at lunch), check the tappets, and see if that helps. we figured its likely the inlet valve is fucked. if that doesnt fix it, then the 1600 will be getting fast tracked into the engine bay. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 23, 2011 Author Share Posted May 23, 2011 ill just stick this here (thanks richie), as a final salute to the mighty avenger. Should see it around here again (another forum member has it now) Quote Link to comment Share on other sites More sharing options...
