coldturkey Posted November 7, 2010 Share Posted November 7, 2010 Hey, Im after a copy of an A15 Engine Manual (from a Nissan Vanette) if anyone has one? Web search turned up nothing. Cheers! Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted November 7, 2010 Share Posted November 7, 2010 What info are you after? Quote Link to comment Share on other sites More sharing options...
coldturkey Posted November 7, 2010 Author Share Posted November 7, 2010 I need the standard sizes and tolerences of piston bore, camshaft, crankshaft, valve guides, bearings etc to rebuild the engine, plus torque settings etc But it would really be good to have a manual in case i get stuck in some places Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 8, 2010 Share Posted November 8, 2010 I have a manual, but no scanner. The library should have a haynes manual for the Datsun sunny. many of them were A15 powered. Quote Link to comment Share on other sites More sharing options...
coldturkey Posted November 8, 2010 Author Share Posted November 8, 2010 ah yep i'll try that thanks. Is yours a Haynes manual then? Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 8, 2010 Share Posted November 8, 2010 yes. I rate it fully. Quote Link to comment Share on other sites More sharing options...
coldturkey Posted November 8, 2010 Author Share Posted November 8, 2010 hey, would you be able to give me the standard bore size and standard crankshaft measurements? and big end/main bearing tolerances and perhaps piston ring gap tolerances. Should get me started(!) Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted November 8, 2010 Share Posted November 8, 2010 Go buy a Haynes manual. $20 or so 2nd hand isn't much of an outlay if you are building a whole motor. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 9, 2010 Share Posted November 9, 2010 hey, would you be able to give me the standard bore size and standard crankshaft measurements? and big end/main bearing tolerances and perhaps piston ring gap tolerances. Should get me started(!) Bore 76mm -2.992in Crankshaft, Main bearings, 49.951-49.964 (1.9666-1.9671in) crank pin, 44.961-44.974mm (1.7701-1.7706in) Ring gaps, Top-7.9thou-13.8thou 2nd-5.9thou-11.8thou oil-11.8thou-35.8thou Piston ring side clearances, top-1.6thou-2.8thou 2nd-1.2thou-2.4thou For more info, buy me some beer, or buy yourself a book. Quote Link to comment Share on other sites More sharing options...
coldturkey Posted November 9, 2010 Author Share Posted November 9, 2010 cheers dude, already owe you beer. Trust me, im looking, but all I can find is $100 ex Aussie! Quote Link to comment Share on other sites More sharing options...
coldturkey Posted November 9, 2010 Author Share Posted November 9, 2010 found one - http://www.trademe.co.nz/Browse/Listing ... =330095200 that one will be the ticket right? Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted November 9, 2010 Share Posted November 9, 2010 nah, that one has the E13/E15 motor. Need one for the DATSUN sunny Quote Link to comment Share on other sites More sharing options...
