R100 Posted August 11, 2010 Share Posted August 11, 2010 Are there any Volvo people on here. I have a boat with a volvo AQ 171C engine in it. From what ive been told it is just a marinised car engine. My engine needs to be pulled down as it doesnt turn over, suspect stuck valve. Can anyone help me with identifying my engine and what car it originated from. Below are a few pics of what it looks like. Its a 16 valve twin cam 2.3 or 2.5 ? liter petrol with twin down draft carbs. Has AQ171C on it. I have found a few pics on the net with what looks to be the same engine in a car, but they are all engine bay pics. Boat engine Car engine Quote Link to comment Share on other sites More sharing options...
durty Posted August 11, 2010 Share Posted August 11, 2010 I think it would be a redblock 16v engine B234F 2.3L NA B204E 2.0L NA B204FT 2.0L turbo B204GT 2.0L turbo or a B23 or B230 http://en.wikipedia.org/wiki/Volvo_B234_engine part about volvo penta Quote Link to comment Share on other sites More sharing options...
Kezo Posted August 11, 2010 Share Posted August 11, 2010 I think it's just a stroked up B230/B234 from the 240/740 series. The head is the same as in the cars, the only great difference being the crankshaft and pistons. IIRC, if you're going to put the marine crank in a car engine, you need to grind out the block a bit or else it won't rotate freely. And somewhere close around that place is an oil channel... Quote Link to comment Share on other sites More sharing options...
bdm Posted August 12, 2010 Share Posted August 12, 2010 If you can find a serial number i can help as i work for volvo penta here in auckland. *EDIT Should be able to tell you the history of that engine as well if the boat was built in NZ Quote Link to comment Share on other sites More sharing options...
R100 Posted August 13, 2010 Author Share Posted August 13, 2010 If you can find a serial number i can help as i work for volvo penta here in auckland.*EDIT Should be able to tell you the history of that engine as well if the boat was built in NZ That would be marvelous. I will try find the serial number this weekend. Im pretty sure it was built in NZ. I know a bit of its history but only back a few years. I dont know a hell of alot about the volvo engines, but when i first saw it the word "turd" came to mind. Ive been told rebuilding them are hellish expensive. The boat was running fine up to 3 years ago where its been parked up ever since, now engine wont turn a full revolution without seizing. I suspect its a stuck valve. If it cost too much to fix ill just repower the boat. Need at least 150hp though. Was thinking a 2LT toyota diesel maybe ? I dunno. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted August 13, 2010 Share Posted August 13, 2010 Holy shit yes 2L-T, it really needs a turbo that won't choke it and it will be magical. Quote Link to comment Share on other sites More sharing options...
bdm Posted August 15, 2010 Share Posted August 15, 2010 If you can find a serial number i can help as i work for volvo penta here in auckland.*EDIT Should be able to tell you the history of that engine as well if the boat was built in NZ That would be marvelous. I will try find the serial number this weekend. Im pretty sure it was built in NZ. I know a bit of its history but only back a few years. I dont know a hell of alot about the volvo engines, but when i first saw it the word "turd" came to mind. Ive been told rebuilding them are hellish expensive. The boat was running fine up to 3 years ago where its been parked up ever since, now engine wont turn a full revolution without seizing. I suspect its a stuck valve. If it cost too much to fix ill just repower the boat. Need at least 150hp though. Was thinking a 2LT toyota diesel maybe ? I dunno. Volvo Penta NZ didn't bring in alot of AQ 171's in to the country, it will be expensive to rebuild and all parts will be ex Sweden as the engine is not that common in nz. I've seen a lot of people marinise the Nissan patrol engines with great success but it all depends on how much room you have. Pm me if you need parts. Quote Link to comment Share on other sites More sharing options...
sentra Posted August 15, 2010 Share Posted August 15, 2010 ^ would you happen to be the younger engineer who was at the boatshows? Quote Link to comment Share on other sites More sharing options...
