HighLUX Posted April 19, 2010 Share Posted April 19, 2010 The van has started using water Oil doesnt seem milky under the cap or on the dipstick and theres no vapour or moisture coming from the exhaust even when its cold so I wonderinging where its going, the only fishy thing is a bit of milky vapour coming from the breather on the catch can. Engine is a Gen2 3sge Quote Link to comment Share on other sites More sharing options...
Requiemk Posted April 19, 2010 Share Posted April 19, 2010 pressure test the cooling system. It doesn't matter which it is when you take the head off you get it checked and or planned and a new headgasket fitted. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted April 25, 2010 Author Share Posted April 25, 2010 Whipped the head off today and it turns out the heads corroded to shit around 1 and 2 cylinder water galleries. Time for a new head Quote Link to comment Share on other sites More sharing options...
Simon Posted April 25, 2010 Share Posted April 25, 2010 Whipped the head off today and it turns out the heads corroded to shit around 1 and 2 cylinder water galleries. Time for a new head These heads are known to go soft as they age. How many kays has it done? Especially if they have been overheated before. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted April 25, 2010 Author Share Posted April 25, 2010 unsure on kms was rebuilt 28000km ago and everything looks mint except the head Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 25, 2010 Share Posted April 25, 2010 weld up and reskim?? Quote Link to comment Share on other sites More sharing options...
forced Posted April 25, 2010 Share Posted April 25, 2010 Probably forgot to put antifreeze in there. That's what happens with water. Steve Quote Link to comment Share on other sites More sharing options...
