d.p.n.s Posted December 24, 2009 Share Posted December 24, 2009 i want to take the tube that the shock sits in out alltogether from the axle can this be done? cheers dan Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 24, 2009 Share Posted December 24, 2009 Your going to need a lot of heat, a good vice and a pipe wrench. From memory the tube is brazed into the stub on Escort struts and the tube has a slight taper at the bottom. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 24, 2009 Share Posted December 24, 2009 Yes you can, They remove them to make bilsteens etc just cant remember exactly how its done. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 25, 2009 Share Posted December 25, 2009 cut tube off at base cut slits in remaining tube chisel the fuck out of it die grind the rest win i manages to find a perfect size hole saw for mine which made life easier Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted December 25, 2009 Author Share Posted December 25, 2009 when you put the new one in mate did you just weld it in there? Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted December 25, 2009 Share Posted December 25, 2009 160 amps sorted it out mate Quote Link to comment Share on other sites More sharing options...
