Carby help
Sorensin
Hi guys
I need to get a new carb for my escort, its a worked 1600 engine. I was just wondering as they seem to be more common can I use a 2Ltr cortina carb and just have it rejetted for a 1600? If so does anyone know anyone good/cheap in auckland who does this? I've been told to try find a 32/36 webber.. any other suggestions.
Thanks
the cortina carb should be a weber 32/36 dgv twin throat
im pretty sure they fit a sport manifold, may need a lil fileing?
there bout the best carb for eskys
some people use capri v6 carbs, i dont know what size these are.
Ok I have a webber manifold for my 1600 and im about to buy a 32/36 from a 2ltr cortina. I've been told I'll have to have it rejetted for a 1600, can anyone reccomend someone in auckland to do this? Want to try get done ASAP
Also ball park figure on cost of doing this?
Thanks guys
yes you will have to have it rejetted to suit ur engine
dont know of anybody in aux tho, i got Ian Kerr in whangas to do mine
my twin dells cost $160 to jet an balance. but it could be up to $500 if the carb needs rebuilding.
not a clue as to the jet sizing, the carb specialist will use a air-fuel ratio meter to find that out.
if you completely strip it down and be extremely matriculate you can do it yourself.
You just need to find the specifications for what size jets your 1600 requires and if they are incorrect buy the correct sizes new.
The sizes should be stamped on the side
May as well but a rebuild kit while your at it, colins in wellington sells them for $60 for the 32/36
