Sorensin Posted July 28, 2009 Share Posted July 28, 2009 Hi guys I'm sure several people on here have done this so I was just looking for some advice/tips/walkthroughs on putting side drafts on my crossflow and what to do about that massive brake booster and mount being in the way... Perhaps a remote break booster because I have heard changing the angle of the mount and shifting the booster down is a nightmare. Thanks guys Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 28, 2009 Share Posted July 28, 2009 undo bolts holding booster in, jump on booster, redrill holes and put bolts back in. Job done. Gaz Quote Link to comment Share on other sites More sharing options...
Escorto. Posted July 28, 2009 Share Posted July 28, 2009 undo bolts holding booster in, jump on booster, redrill holes and put bolts back in. Job done.Gaz +1 i went the other way. (pedal box) its not worth the trouble. just gota make sure your engine has enough vacuum, been told really lumpy cams can affect this i dont think jumpin on the booster is needed. but you'll find out. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted July 28, 2009 Share Posted July 28, 2009 +2 if you undo the bolts you can just push the booster down till you have room for the carbs......but in saying that jumping on it would be more fun dan Quote Link to comment Share on other sites More sharing options...
