cute wee gem Posted May 21, 2009 Author Share Posted May 21, 2009 have you thought about plugging your hole eg press fit a pin/plug and grind it smooth? require no welding/destroying Yep was going to do this + epoxy the big ditch in the middle of the port, anyway it's staying there for now after all that. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted May 22, 2009 Share Posted May 22, 2009 if you wanted to use a epoxy i'd use defcon... to get them out you'll prob need to preheat head, like when you do valve guides, preheat head in the soak bath if it was me, id press them out hot then spin up some alloy bits the same size, press them in then weld over and i recon there for emmissions Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted May 22, 2009 Share Posted May 22, 2009 where does one buy this defcon going to have some alloy casts made up of the voids then bolt them in from the injector hole and seal/smooth off with 'defon' Quote Link to comment Share on other sites More sharing options...
kpr Posted May 22, 2009 Share Posted May 22, 2009 devcon maybe. blackwoods and other trade type places like them have it. Quote Link to comment Share on other sites More sharing options...
