Beaver Posted May 4, 2009 Share Posted May 4, 2009 as above, will extractors from a 1500 cortina motor fit onto a 1600 cortina motor? did a quick search but couldnt find anything... cheers Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 4, 2009 Share Posted May 4, 2009 No. 1500 = pre-xflow, 1600 = xflow. AFAIA Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 4, 2009 Share Posted May 4, 2009 KY is right. They will not fit Quote Link to comment Share on other sites More sharing options...
mkcortina Posted May 4, 2009 Share Posted May 4, 2009 Im pretty sure they will you just have to modify 1600 to fit a 1500, by cutting the half the bolt holes off so the intake will fit between them. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted May 4, 2009 Share Posted May 4, 2009 ^ The bolt spacing is much the same from memory but I doubt they would seal well and 1600 extractors are only about $220 brand new so I woudn't bother trying Quote Link to comment Share on other sites More sharing options...
mkcortina Posted May 4, 2009 Share Posted May 4, 2009 ^ The bolt spacing is much the same from memory but I doubt they would seal well and 1600 extractors are only about $220 brand new so I woudn't bother trying i was just abouyt to write that. Yeah if you use 1500 extractors you will fing the bolts will work them self loose. It is better to just get some new extractors. Quote Link to comment Share on other sites More sharing options...
