Jeffs_Emporium Posted February 12, 2009 Share Posted February 12, 2009 can anyone tell me if the colum change gearbox can be changed to floor shifter on rwd 4g63 l200 box?if so what do i need to do it and will the box have mounts underneath for my sapporo crossmember?cheers boes Quote Link to comment Share on other sites More sharing options...
fuel Posted February 12, 2009 Share Posted February 12, 2009 I don't think you can easily, at the very least you'ld have to find the rear tail housing from a Sigma gearbox. Crossmember shouldn't be a problem. Did you get another gearbox? Cause that gearbox from your '79 ute is for a 4G52 engine, not 4G63. Quote Link to comment Share on other sites More sharing options...
Jeffs_Emporium Posted February 13, 2009 Author Share Posted February 13, 2009 na just saw a cheap one on tm for 70 but its column shift, ive got a guys number who has a sigma box for 2hundred so ill get one in the next couple of weeks, then i just need a powersteering pump, exhaust manifold and full system and some wheels that are the right offset haha and itl be all go, do u have your old exhaust system still?would you be keen to sell? Quote Link to comment Share on other sites More sharing options...
Ogre Posted February 14, 2009 Share Posted February 14, 2009 a 4g52 box should fit a 4g63 ok shouldnt it?the dude i sold my 4g63 just replaced his 4g52 in his sigma and it just bolted in... Ive got a rebuilt sigma gearbox and a powersteering pump if ya need em Quote Link to comment Share on other sites More sharing options...
Jeffs_Emporium Posted February 14, 2009 Author Share Posted February 14, 2009 my gearbox that was connected to my 4g54 that was in my sapporo wont fir my 4g63 that im trying to put in it all four bolts are further apart on box than block, does this mean i have a wideblock gearbox?!?!?!how much you after for box and pwersteering pump? Quote Link to comment Share on other sites More sharing options...
Jeffs_Emporium Posted February 14, 2009 Author Share Posted February 14, 2009 and the gearbox thats in my 79 ute had a 4g63 engine on it , fuck this shiz is confusing Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 16, 2009 Share Posted February 16, 2009 4g54 = wideblock, 4g52 = narrowblock, in my experience, no one knows what the fuck mitsy were up to sometimes though. I put a 5 speed from a 4g63 l200 into my 4g52 l200 with no issues whatsoever. Quote Link to comment Share on other sites More sharing options...
fuel Posted February 16, 2009 Share Posted February 16, 2009 4G54 aren't all wideblock, only a few of them are. And we don't even know that it's a 4G54 which was in your Sapporo dspec_tt131, it could be any Astron series motor be it 4G51, 4G52 or 4G54. The lower and outer most bellhousing bolts need to be measured for spacing - 310mm for narrowblock and 330mm for wideblock. Quote Link to comment Share on other sites More sharing options...
fuel Posted February 16, 2009 Share Posted February 16, 2009 and there are a few different variants of gearbox too, so if one gearbox from one car doesn't fit, it doesn't mean all gearboxes from that car wont fit etc. I've seen some later 85-86 4G63 Sigma wagons with two different bolt hole sets at the top of the gearbox. FWD Sigma autos also have that extra hole about 15-20mm apart from the other top bolt. Quote Link to comment Share on other sites More sharing options...
Jeffs_Emporium Posted February 17, 2009 Author Share Posted February 17, 2009 alright well when i slot my astron box up to my 4g63 both the top and bottom bolts are further apart Quote Link to comment Share on other sites More sharing options...
Ogre Posted February 17, 2009 Share Posted February 17, 2009 $250 for the lot and some old clutch plates and pressure plates etc.and an old l200 box if ya want it Quote Link to comment Share on other sites More sharing options...
Jeffs_Emporium Posted February 17, 2009 Author Share Posted February 17, 2009 found one for cheap just around the corner sorry mate Quote Link to comment Share on other sites More sharing options...
