ZedHed Posted August 1, 2008 Share Posted August 1, 2008 Heyas. I rekit my master,and still got ning the brakes.Looks to be bled cause you get fluid under pressure with air then no air,as a normal bleeding session,but still nothing at the pedal after.It drops to the floor when I undo the nipple,but still nothing. Also the valve between the booster and the intake groans as the pedal is pushed down,and then the pedals slightly slow to come back to normal height. Im fuckin stumped eh. Theres no leaks anywhere so ill be poked if i know where to go from here? any ideas lads? All i need is brakes and im off for a wof,after 3 yrs! Quote Link to comment Share on other sites More sharing options...
tortron Posted August 1, 2008 Share Posted August 1, 2008 not sure on the make up of your m/c but if you do it from dry you can "over reach" the piston which results in it bypassing, and then it cant go back to its normal position samething happens if you put the cupped washer in the wrong way. Thant said yours is probably completely different to what im used to Quote Link to comment Share on other sites More sharing options...
plasticdash Posted August 1, 2008 Share Posted August 1, 2008 Was it doing a similar think prior to re-kit ? Quote Link to comment Share on other sites More sharing options...
ZedHed Posted August 1, 2008 Author Share Posted August 1, 2008 cheers guys. It seemed to be a simple rekit,just two seals on the shaft,one at each end. It was doing this before the rekit,so ive just biffed $52 down the shitter. Ill pull it apart and bench bleed it again. RRRR Thanks for the replies man. Quote Link to comment Share on other sites More sharing options...
Requiemk Posted August 1, 2008 Share Posted August 1, 2008 i have spare master of 260c runs l26 so mayb4e same stuff, can sell tbh nothing ever works out how you want it to Quote Link to comment Share on other sites More sharing options...
ZedHed Posted August 1, 2008 Author Share Posted August 1, 2008 if its the two pot tokiko set-up,it will be the same....7/8ths not 15/16ths. How much would you want for it man? Quote Link to comment Share on other sites More sharing options...
ZedHed Posted August 1, 2008 Author Share Posted August 1, 2008 just wondering,could the vacuum servo be stuffed? I know little about brakes,sorry guys. Quote Link to comment Share on other sites More sharing options...
Requiemk Posted August 1, 2008 Share Posted August 1, 2008 eh cheap, i no how annoying these problems can be. Will check outer housing tomorrow as it should be stamped into/? brake booster fucked would just give you hard to push pedal. Quote Link to comment Share on other sites More sharing options...
plasticdash Posted August 2, 2008 Share Posted August 2, 2008 Mate had the same problem as you. tried everything, brand new master, bias valve and vacuum, blew out lines, bled many times using foot and also vacuum bleeder. turned out that one of the brake pistons was sticking. wouldnt move when bleeding, but would when under pressure. caused similar issue to what you have. also take out your bleed nipples and make sure the holes in them are not clogged (ive had this one myself) Quote Link to comment Share on other sites More sharing options...
Unclejake Posted August 4, 2008 Share Posted August 4, 2008 Heyas.I rekit my master,and still got ning the brakes.Looks to be bled cause you get fluid under pressure with air then no air,as a normal bleeding session,but still nothing at the pedal after.It drops to the floor when I undo the nipple,but still nothing. Also the valve between the booster and the intake groans as the pedal is pushed down,and then the pedals slightly slow to come back to normal height. ZedHed - TBH your description of the problem is a bit hard to follow so I am guessing. Are you unable to get pedal pressure at all? If that is the case and the fluid level in the M/C reseviour is not going down then you probably have missed installing the small platsic cap on the M/C end of the activation rod (the rod that comes off the pedal) Quote Link to comment Share on other sites More sharing options...
Jase Posted August 11, 2008 Share Posted August 11, 2008 uj the champion master fix it Quote Link to comment Share on other sites More sharing options...
Unclejake Posted August 12, 2008 Share Posted August 12, 2008 True? Sweet. Guess that was a cheap solution FTW Quote Link to comment Share on other sites More sharing options...
