d.p.n.s Posted July 6, 2008 Share Posted July 6, 2008 hi all im trying to wire up this escort of mine the wiring is all other the place and its got and old type starter on it with the solinoid on the wirewall. so 1st Q i have 2 wires going to here witch one goes where 1 red/black 1 yellow/black also the power goes from the battery to here and no where else is that right? cheers dan Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted July 6, 2008 Author Share Posted July 6, 2008 ok so these are the wires im havin a problem with battery side of car 1 black/yellow (think it goes to the solinoid) 1 re/black wire (think it goes to the solinoid) 2 brown wires joind together(think its an earth) 1 brown wire buy its self (could be an earth) drivers side black wire from dizzy(- on coil i think) 1 red wire (could be for horn) 2 black yellow wires 1 muct be for coil. any help guys and also there is only one power cable and that goes to the stater solinoid like in pic but that is the only power suply is there ment to be anyothers? and when i put a test light on the other points on the solinoid thers no light? fuck i hate wire up cars that i didnt un wire. Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 6, 2008 Share Posted July 6, 2008 I can't remember much of the color coding for the Escort so I can't really help, but I can say the 2 brown wires joined together are an earth and are bolted to a small hole in front of the strut top. And there should be a heavier gauge wire that is the power supply for basically everything in the car which should come out of the loom up by the battery, mine had been cut and extended/replaced a few times but i think it may have been a red wire. The solenoid is easy to figure out as long as you have got power at the ignition, just use a test light and find which wire goes live when the key is turned to start. Relaying pretty much everything is a very good idea if you can be fucked doing it! and when i put a test light on the other points on the solinoid thers no light? There shouldn't be, 1 spade terminal is an output for the ballast on the coil, the other engages the solenoid when it gets power. Quote Link to comment Share on other sites More sharing options...
sholdowa Posted July 6, 2008 Share Posted July 6, 2008 I've got a mk.1 manual if that helps... can bring it in tomorrow? Black/yellow: starter solenoid -> coil ( 12 volt override for starting ) thin red: starter solenoid -> regulator Black/Red: Stop light switch -> fuse box or connector -> rh indicator Brown: Look to be inside - choice of... Wipers Internal light Cigar lighter Courtesy switches -> internal light Distributor connects to coil only ( well, and earth ). Don't think the horn's red. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted July 6, 2008 Author Share Posted July 6, 2008 thanks guys well 2 browns ive earthed single bown when i looked depper ended up being red and is ingnition power from battery so i now have it turning ober from ignition also have spark fom plugs and its back firing threw the carb....so any ideas i wa thnking time out 180 ...... firing order i belive is 1.3.4.2 ...i think Quote Link to comment Share on other sites More sharing options...
sholdowa Posted July 6, 2008 Share Posted July 6, 2008 thanks guysi wa thnking time out 180 ...... firing order i belive is 1.3.4.2 ...i think Pintos yes. Kents no. 1.2.4.3 Quote Link to comment Share on other sites More sharing options...
LAN_KILLA Posted July 6, 2008 Share Posted July 6, 2008 is it running lucas electics? and is it +ve or -ve earth? If so then normally a brown wire is one that has constant +12V (So is connected to the solenoid on the same post as the battery terminal) Those brown ones youve earthed are probably your headlights or some other accessory that isnt key controlled Quote Link to comment Share on other sites More sharing options...
