A very strange question about testing ignition timing
Unclejake
Shanks were good! Had potatoes too :shock:
Your suggestion makes sense. Let me get a photo to be certain we are talking about the same thing but at this stage I think increasing the air gap would require cutting the steel posts that 'activate' the trigger/reluctor.
I am grateful for the advice. I will get a photo tomorrow and post it on Wednesday.
  • Replies 86
cant cut the posts
but you could reshape the ramp... the ramps just conditioning anyways IMO
keen on pics :D
glad i can help
anythign good to eat tonight ?
we had hotdog's and chips...yum
You realise that with your setup the HT will never exceed 2 to 3 Kv. With that there's a possibility that your timing light might not be triggering properly.
In a "real" motor the HT will go up to maybe 25Kv under load.
I'd be doing a comparison with a "stock " cortina dizzy.
Steve
i see whats forced is sayng
becauae the real motor has compression there is more resistance in the spark gap so in real world it will load up more and make more voltage to arc across the airgap
could be simulated by just increasing teh spark gap or putting a large ballist on the earthing plate
though this would show as a inconsistant spark or a weak spark ......it shoudlnt change the timming
its a reluctor setup so the trigger isnt dependant on the coil/points at all
if your static timming was 0
advanceing would be BTDC
retarding woudl be ATDC
hope this helps
The signal to the timing light seems fine except at very low RPMs (on the test rig). Now that I have the rotor phasing right the signal is steady - even at 8,000 RPM
The issue is this retard at medium revs.
Photos will be taken tonight and we can look at widening the air gap to possibly solve the problem.
hope this helps
tis true - one thing I learned from Sefton was you may get a decent spark out of a plug at 1 atmosphere but with compression
it may misfire.. not too sure how or if it will affect the timing because the signal should be the same but it will definetly affect the actual spark intensity at the plug electrode..
The magnetic pickup (hall effect) has a slight fixed delay to it. The rise time in the coil also causes a slight fixed delay. The higher the voltage before current flows, the more delay.
So at low rpms, only a small fraction of a degree.
Higher rpms, more degrees
more voltage, more degrees.
As for coming right at the top end, I'll pass on that, too hard.
Steve
Here is a photo.
This is the EXACT moment the spark appears. Don't forget the distributor runs anti clockwise and I have phased the rotor timing within a degree or two of perfect by observing the rotor with a timing light and a hole in the dizzy cap.
My problem is several degrees of retard as the dizzy spins faster
Look at the reluctor (or trigger??) - reckon I need a balast resistor???
By unclejake, shot with DSC-R1 at 2008-08-
you supply power to the dizzy at all ?
just makign sure
subaru is a vr setup
I don't know what 'vr' is sorry.
I have been supplying power to the dizzy as per the way I wired the race car. That wiring system is replicated on the test rig without the MSD gear. You can't really get it wrong with those dizzys as the don't sparj at all if the polarity is wrong. The dizzy is ex. Subaru Leone
The spark looks great. It is just the rising retard that shits me :?
