brocky41 Posted May 24, 2008 Share Posted May 24, 2008 Hey guys need help on what i need to get this baby running. Ive just purchased a CA18de with loom and computer 5 Speed with yolk for TUFDAT the 120y. As im converting it to fuel injection, i need to know if the standard steel line is big enuf as iv got aspare to use as the return(easy fitment) also what fuel pump to consider etc as i will need to run external. im using factory loom and computer and would like to know how much to wire something like this costs. any help greatly appreciated Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 24, 2008 Share Posted May 24, 2008 Standard lines are fine as im guessing they will be 8mm from standard Cheapest option for fuel pump is either a Holen VL pump or one of the skyline external pumps... VL easier to find tho. Depends on labour costs as to wiring, I would say anywhere from $500-1000 tho or even more if you want it hiden. Quote Link to comment Share on other sites More sharing options...
brocky41 Posted May 24, 2008 Author Share Posted May 24, 2008 shit its still that much even if iv got the standard loom all layed out in the car with everything mounted up , gona be a little more than i thought. Quote Link to comment Share on other sites More sharing options...
peteretep Posted May 24, 2008 Share Posted May 24, 2008 man what world do you live in you have to use the 3 times whatever you thought it would be rule Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 25, 2008 Share Posted May 25, 2008 The fuel line will only be 1/4. You really want to upgrade it to 3/8. This will include the tank pickup. Email datsunboy, He should be able to give you a diagram of how to wire it up. With the datto site down, PM me if you need his number/email. (If you dont have them) If you have a few skills, you should be able to tackle the loom yourself. For a DE motor, you shouldn't need a monster fuel pump. It would be wise to incorporate a surge tank into your set up too. It sux that the datto site is down Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 25, 2008 Share Posted May 25, 2008 1/4 is way small. Even mk2 Cortina is 5/16 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted May 26, 2008 Share Posted May 26, 2008 It sure is. Bear in mind that the B210's only came out with an A12. (69HP at the flywheel without running any accsessories, alt, fan,water pump) Quote Link to comment Share on other sites More sharing options...
