tortron
Tortrons series mm minor of slow
10 points if you can tell me what this is and where it goes (i just made it by hand because i put the original in a safe place, so i know damright what it is :lol: )
Share this post
Link to post
So
set some time aside to work on this again
so far
Engine, gearbox and front suspension are out - all of which are caked solid in hard crap
engine bay is about 80% stripped, taking it right back because most of it has surface rust breaking through
Small amount of rust in the battery box, probably wont fix it (had some steel pop rivited over) Will make up a wooden case job to sit in there as its a pretty big space for a battery. This will hide anything i dont want to see :lol:
some pitting where the radiator overflow drips on.
However i have uncovered an unhealthy patch of rust hiding under the drivers side engine mount. Will need a patch made. No big deal, just another item on the list
List seems to be always getting bigger, but progress is progress right? (would have liked to be driving at the end of the week, could have done if i had just put the seats back in and filled up the tank :lol: oh well)
Share this post
Link to post
Some nasty pictures
Rust here was hidden nicely under the engine mount tower
This is the front sill section nearly directly under that mount. Basicly from that rust back about a ft on each side has been replaced with a rough patch (they should have made it an inch longer eh)
Good news is that that should be the last of the rust repairs.
Split my engine and box today to check it out - one of the springs on the clutch had broken, and was probably part of my clutch problems way back when this thing was driving. Nevermind, i have two spare boxes and a new clutch (part number is the same as the 803 a series incase anyone cares) so will all go back together better than before.
Next on the list is to re-captivate the gearbox crossmember captive nuts
Then take out the diff and springs, so all that can be stripped back, painted and any rubber bits replaced as needed
Wanted to do that today, but i dropped the damn gearbox on my fingers. Its small, but almost a solid lump of cast iron, now my fingers are simply too fat to work on the dinky little nuts and bolts in this :lol:
Share this post
Link to post
This was the "clean" side
Combination of soaking in degreaser, standing infront of a bench grinder with wire wheel for 2 days, wire brush on a drill, and scraping with a flat edge cleaned them up ok.
Drivers side grease had gone rock solid, fortunately it hadn't worn any of the assemblies. Have ordered a new swivel pin as this one was badly pitted (and has been for quite some time it would appear). Parts are cheap so why not, also ordered a bunch of rubber dust seal etc
Now looking like this, note the brass trunnions.
Went for a basic black and silver, would have been similar from factory (depending on what day of the week it was). Havnt bothered with a full polish on any of the parts, i prefer a clean brushed look over mirror finish. Should look good with the brake banjo connectors on there. Should also handle nicely too.
Parts you cant see - fresh grease in everything, fresh oil in the lever arms, torsion bars trimmed to drop the front circa 2 inch
Share this post
Link to post
Morris minor gearbox as found in its natural habitat
Grease and grime removed. Painted partly in stationary motor grey, and a red which i believe is original (all my other gearboxes have this red)
And painted, looks a bit orange on my screen. Red is ok, could have been a bit darker. Will do the engine the same
Share this post
Link to post
The brother came over the other day, and we spent most of it eating cakes and pies, drinking coffee and occasionally rubbing the old lump (in amongst this the engine got cleaned too)
Its shiny, so that means its rebuilt right?
(acutally before this i decoked the head and will reset the valves once its running. Thats all this old girl wants)
Ignore the painted park plugs, they are just there to stop me painting the threads. Might do the head nuts black for a bit of contrast, and go over the alloy bits - timing cover, sump etc again.
Clutch is off for replacement, contemplating shaving down the flywheel, but i probably wont.
Also rebuilt the front brakes, so all that is done
Share this post
Link to post
Clang, Boom, Steam
rust cut, whiskey drunk, patches cut, whiskey drunk, patches welded, whiskey drunk, shed caught on fire, whiskey drunk, whiskey drunk, bed
Think i will drill a wee hold in the middle of where the engine towers mount, so i can inject fishoil or what have you into the front chassis rails
Share this post
Link to post
have since put another coat on/got all the bits i missed
was a bit more dust in the shed than i had liked (outside was far better when i painted the rest of it)
but whatever, its better than factory :lol:
Share this post
Link to post
Standard Flywheel weighs 7.85 KG/17.3 lbs
Flywheel now weighs 5.55 kg
Shiny
Should keep up with the morrie 1000's now
Share this post
Link to post
Spent the last 3 days under the rear end
several stuck bits, soaking & a couple of hammer blows has gotten the driveshaft, diff and suspension out.
Will need new front pins for the springs, rear shackle pins, new rubbers everywhere, connecting arm for the armstong shock
Will take the diff to washworld tomorrow, steam blast the inch of gunk off it.
Wire brush everything
paint everything.
Diff seals look ok, it never dripped much, cleaning may change that
next steps
clean up underside rear
have done the rust here already, so its just paint and reassemble.
My lowering blocks dont fit, they are too big for the titchy diff spring mounts, locating pins are different too and the design of the blocks doesnt permit me modifying them. Will get some made and get new u bolts.
Will make new brake lines while im down there.
After that, its - pull the sump and switch the flywheels
replace all the seals there
Remove the remains of the "fixed nuts" for the gearbox crossmember and fit standard nuts and bolts.
Bung in gearbox.
Clean up and reinstall all under bonnet equipment
soundproof rear half of interior
fit underlay and carpet
retrim interior panels
finish my custom instrument gauge
get a new exhaust system made
once im all back together and running, i will gather up all the bits required to fit the water pump.
Fit tiny amp, hidden speakers and mp3 input
and hopefully get some miles in
Share this post
Link to post
Found some more rust in the body beneath the left hand rear spring eye. 3"x1" patch and that should be the last of it. Cleaning the undersides of cars is a horrid job.
Exciting news!!!!
I have now removed everysingle removable part of this car
Share this post
Link to post
Welded up the rust in the rear today.
Also ran one side of the rear brake line. Took a while, but looks good. Have held the lines down with some original and now impossible to get brass zip ties. Hopefully there are some more in my spares for the other side.
Got quoted about $400 for a set of lowering blocks for this. So it looks like my money will be going to the uk yet again.
Plan on por15ing the entire underside floor tomorrow. Am unsure if i then want to put on some underseal. I have always stripped it off my cars and cursed whoever put it on. But with a good base and it all being fresh i can see yye benifits in cutting down on road noise. Il think about it, as i already have a dynamat type deadening, then under carpet stuff, then carpet. So its going to be alot quieter than it was when i was driving it (only had metal floors).
Plenty to do, but progress is slowly building. Wanting to sell off my other vehicles and daily this again, seems a long way off, but once my ordered parts show up i should have it on all 4 and the sump+gearbox back in within a few days
Share this post
Link to post
Tapped the bottom axle locating hole and loctite'ed a bolt in there. The one was open to the half shaft, this should prevent any oil loss. I think that the other 3 will be fine with the rubber grommets.
Ran the other rear brake line, and also the front offside line.
Stripped down the rear cylinders and master cylinder and cleaned them out. They are looking good (were resleeved in stainless and rekitted when i first got the car).
Have reassembled the rear brakes, i am even using beehive springs.
There is still a seemingly endless list to do
Share this post
Link to post
Have put on 2 coats of por15 on the underside
my package from bull motif came today
so i have all my new suspension rubbers, fender welt, and a few other bits.
They didnt mention the gaskets wernt in stock when i ordered. But a note in the package did. Not that impressed as i probably would have ordered from esm again if i knew that. Oh well, i was making a second order soon too as i have found some bits are missing
Share this post
Link to post
Some og members may remember the bit of trouble i had with the alloy water gallery/generator mount.
Its held on with 5 bolts. I snapped off the middle one flush
then snapped off an easy out in there.
I used knead it to seal the cover and this worked perfect, with the proviso that i would fix it propperly at a later date.
Today i drilled it out. Colbolt drill bits cut through like butter, will retap when i get a 5/16 unf tap (iv only got unc for some reason).
Also cleaned up the start of the thread on the offside shock arm (must have knocked the very start of the thread with something. I had the nut off with aspirations to dismantle and rebuild, turns out you need heat anf 5+ ton of pressure to pull the arm off, so i cancled that idea)
Wont be putting a heater in just yet, so i machined out the heater take off on the pump so i can fit my temp sender in there. Il probably end up just putting a cap on this and drilling out the blank on the head to fit a brass male to male fitting. Just need to borrow a drill press for a few mins to get it in square.
Also pulled out the fuel tank. The hammerite i used hasnt sticked very well in places, so will repaint and refit with new screws.
In summary, waiting on a bunch more bits.
Short list of work to do:
Lowering blocks to go in
diff, driveshaft & rear suspension to go in
turn torsion bars down 2 notches to match rear
uprated oil in armstrong shocks
refit master cylinder and run lines to front and rear union
New gaskets and seals throughout engine
fit lightened flywheel
fit clutch and gearbox
fit water pump (i have all the "conversion" parts - you have to blank off where the lower radiator hose goes to the engine, then run a new hose and metal pipe to the pump. Im only missing the metal pipe. Will kindly ask a plumber to make a copper one.
Clean, paint and refit under bonnet equipment - distributor, fuel pump etc
thats roughly all i need to do....
Share this post
Link to post
Phone pictures, have more indepth ones on my camera. Will dump more at some point.
finished diff, hasnt leaked anymore so i must have sorted it. New brake lines and rebuilt brakes
drilled the water gallery blank in the head.
1/2" all the way through for the probe, then 19/32" halfway to tap to a 3/8bsp fitting.
Brass 3/8 male-male fitting has 1/2" machined out of the first 1/4" to match the step on the probe bulb.
Fits wonderfully, hopefully the capillary hasnt been damaged in the last 4 years!
Share this post
Link to post
Flushed out the rear armstrong shocks.
Turns out they are rebuilt units - can see the replacement plug on the rear side. This explains the good condition and being the only part of the car not leaking.
Another giveaway is the gasket under the filler cap. They didnt punch any holes in it, makes topping up a bit hard. Haha
topped up with fresh sae.30 & painted
Share this post
Link to post
