treggo Posted January 12, 2008 Share Posted January 12, 2008 in theory it shouldnt bottom out the shock more than normal. But if you add thicker oil it would help that. Cutting springs they become stiffer but standard springs are still too soft for extreme lowness. How? Isn't it making the part of the shaft inside the shock itself longer? Thus making it closer to the bottom? Thats how I see it too Quote Link to comment Share on other sites More sharing options...
SloNLo Posted January 12, 2008 Share Posted January 12, 2008 nope its spacing the topout spacer up the shaft. total lengh of the shaft is unchanged in this pic the dark gray spacer slides of the shaft the the left then the red spacer can be slid off followed by the white the steel braket left is attached to the shaft and dosnt move here is a comparison to make things clearer each shock showen bottemed out and full extention it shows that the spacered shock will bottem out just like a factory one will but will hold a shorter spring captive the shortened shock will hold the same spring as the spacered shock captive without botteming out as easily hope that makes sence Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted January 12, 2008 Share Posted January 12, 2008 DELETED Quote Link to comment Share on other sites More sharing options...
treggo Posted January 12, 2008 Share Posted January 12, 2008 Cheers for that. Quote Link to comment Share on other sites More sharing options...
Maru-So Posted January 13, 2008 Author Share Posted January 13, 2008 Ah.. yea no your right. you effectivly remove twice as much from the stroke from standard with a spacer. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted January 13, 2008 Share Posted January 13, 2008 Ya don't want the spacer there coz then thats hitting the top of the shock tube, not the washer thats suposed to hit it. It probably wouldn't work at all with the spacer at the top. Quote Link to comment Share on other sites More sharing options...
