dylan Posted November 3, 2007 Share Posted November 3, 2007 well this should definetly win noobest post of the year but just remember that im young and still learning shit(first hand) and excuse the shit drawings which one of the two below is right which ever one of these is correct.....the picture below shows whats happening the bit that i have circled red is moving around freely in the housing that i have circled in blue when i undid the clamps on the rubber boot type thing and had a feel inside it a whole lot of plastic like shraps came out so is anyone able to tell me exactly what the fucks wrong here any help would be greatly appreciated cheers Quote Link to comment Share on other sites More sharing options...
thminiman Posted November 3, 2007 Share Posted November 3, 2007 first ones correct, also know as inner and outer tie rod what where/are you trying to do? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted November 3, 2007 Share Posted November 3, 2007 The bit circled in red in your first photo is your tie rod end. Should have a hex bit at the end of it to put your spanner on and one on the rod of your steering arm to undo it and should just come off and unscrew. [/img] Quote Link to comment Share on other sites More sharing options...
dylan Posted November 3, 2007 Author Share Posted November 3, 2007 what where/are you trying to do? cheers guys...... my problem is the shaft moving freely in the housing-shown in third picture like you can literally shake it with your hand and obviously this shouldnt be happening because if i hit a bump in it the whole left strut moves a bit im just wondering if there is a part in there missing/or something that commonly fucks out in them etc and as i said earlyer heaps of plastic shraps came out of there and some of the little bits look like they may even of had a thread on them Quote Link to comment Share on other sites More sharing options...
thminiman Posted November 3, 2007 Share Posted November 3, 2007 where the tie rod goes into a solid arm, theres a ball joint type thing, that will just be fucking worn, once you get hold of a new one, you'll see how it goes on. and in turn the old one comes off Quote Link to comment Share on other sites More sharing options...
Abarth Posted November 3, 2007 Share Posted November 3, 2007 Where the tie-rod goes into the main tube there is a plastic bush that holds the rod in place in the tube. The broken up plastic is probably the remains of the bush. The bush if fairly small its like a finger ring almost. Should be noted in a Haynes manual if you have got one. Quote Link to comment Share on other sites More sharing options...
dylan Posted November 3, 2007 Author Share Posted November 3, 2007 Where the tie-rod goes into the main tube there is a plastic bush that holds the rod in place in the tube. The broken up plastic is probably the remains of the bush.The bush if fairly small its like a finger ring almost. Should be noted in a Haynes manual if you have got one. oh ok so how would i go about getting one of those/installing it Quote Link to comment Share on other sites More sharing options...
Abarth Posted November 3, 2007 Share Posted November 3, 2007 I think BnT have them, because my mate used to work there and he had the same problem with his Strada. He actually used a Ford escort bush in his Strada so its very similar to the escort Ask for an 'inner tie-rod bush'. When I did mine I brought the proper bush for $10. Is not too bad job I took the whole steering rack out and replaced the bush. I just followed the Haynes manual. Quote Link to comment Share on other sites More sharing options...
dylan Posted November 3, 2007 Author Share Posted November 3, 2007 sweet thanks for your help mate Quote Link to comment Share on other sites More sharing options...
Abarth Posted November 3, 2007 Share Posted November 3, 2007 I probably explained all that like shit, so heres a picture of my fiats steering rack. I think thats your problem; the bush with the red arrow. Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 3, 2007 Share Posted November 3, 2007 seeing as the hard bit is done on your rack, you should take the whole thing out and give everything a clean while your at it Quote Link to comment Share on other sites More sharing options...
dylan Posted November 3, 2007 Author Share Posted November 3, 2007 thanks abarth that pictures helps alot....... and yea ill clean everything up as there could be little bits of plastic still in there Quote Link to comment Share on other sites More sharing options...
