escort wiring
63swb
hi, just wiring up my mk1 escort. this might sound stupid but with the starter motor there is only two terminals and im not sure which wires go on them the both seem to be grounded. i tried putting a big one from the battery on but it shorted it and turned the engine over. any help or a wiring diagram would be great thanks.
If its got a separate solenoid i.e. not attached to the starter, it's inertia, but there should only be on contact on the back of the starter which goes to the solenoid, then the negative battery cable goes to the other contact on the solenoid/i think. did mine a week ago but sold the car so can't check. 90% positive though.
big power cable to solinoid from battery, then big from solinoid to starter, the solinoid will have a smaller trigger wire which comes from your ignition switch
Why are there 2 wires? Ones yellow black, the other red black.
ive just got the red one hooked up, cudnt see anywhere for the otha 1 to go?
