  • Replies 51
Yeah into the cortina and used as a daily. Was going to turbo later but will see how this goes for now. Would'nt do anymore mods to it as its a daily.
Cool, I have a cam from snow in palmy, and have been offered, Cam bearings that are standard,
Mains bearing shells -0.25 undersize
Big ends shells -0.25 undersize also
Pistons and new rings are +0.50 oversize
here's a pic of the of the parts I have been offered for a hundred bucks. Worth it?
Oh my car will be my daily.
Def worth $100.
Keep in mind you will need a crank grind and rebore to run those bearings and pistons.
So thats usually $200 for rebore and about $150 for grind. Well all depends where ya go but you should be able to find that price or a tad less.
very much so, pistons alone are worth twice that
The pistons from Ripco retail for $350 I think. I got a place who can do em for $105 and I know Bowdins does em for $200 a set.
Mint. I'm not doing to bad then. Oh I got the cam for $50 new off 2fknlo.
Fuck thats good. What grind is it?
Costs $212 from Snow for a grind and followerrs to match. Make sure to run cam in properlly as they like to eat themselves.
Also sorry to sound n00b but why would you want undersize shells?
Because the crank gets oval so they have to grind it smaller to get it round again. So you need undersized bearings..
wheras with the pistons you are boring it out to get rid of the lip in bore so you need oversized pistons. :D
Thats a fairly big cam. I personally wouldn't use one like that for a daily driver.. actually.. I say that now because I did use one like that in my capri when it was a daily driver back in 2001.. lol
twas a bit of a pig
you will need twin45 carbs to fuel that properly. Also.. a bitch for a daily.
Heh I got it for 50bucks If it runs like crap i will flick it. Do you think it will be alright with an unported head?
P.s. Thanks for the help boes.
You can run any cam with an unported head it just wont do fuck all good as the head have reduced flow at top end. Cams generally move the power band up and give you more revs, if you cant flow up there then the cam is pretty much useless.
It may struggle up top without the right headwork and carbs.
