CylinderHead Posted September 18, 2007 Share Posted September 18, 2007 little while ago i honed out my master cylinder and replaced the seals as it was leaking fluid. breaks go all good now, but occasionally loose pressure, not at random, but like sometimes if you break and then back off a bit and then break and then back of and then break etc etc the peddle goes further and further down until it hits the floor. so what i want to do when i have a tiny bit more money is get the master cylinder re-sleved. or if someone has a better idea, keen to know. but just wondering if anybody knows a good place to get this done??? i.e cheap/do a good job - but often you don't get both so somewhere that will do a good job? any help would be great Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 18, 2007 Share Posted September 18, 2007 is it losin fluid? drum rear? tried adjusting them? also, possibly has air in system or some shit. there's a couple f places, one's called apex auto centre, in hamilton the other's giant rebuilds. that's in has too I'm pretty sure. anywho, either of them should rule your face for a resleeve, that is, if you can't get a new cylinder? Quote Link to comment Share on other sites More sharing options...
CylinderHead Posted September 18, 2007 Author Share Posted September 18, 2007 its not loosing fluid, levels stay the same. not air in the system, bled the breaks when i put it back together, also if it was air in the system it would be consistently spongy, brakes are all g , just peddle drops sometimes, like fluid is escaping past the seals. not sure if i can source a new cylinder, will try. also depends on cost, will see how i go. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted September 18, 2007 Share Posted September 18, 2007 if levels stay thesame, isn't that telling you that the master cylinder's fine? food for thought Quote Link to comment Share on other sites More sharing options...
V8Pete Posted September 18, 2007 Share Posted September 18, 2007 Mine was fucked and not losing fluid. It might be worth talking to Trade Parts on Wairau Road - they seem to be able to get nearly anything new for not *that* much money. Quote Link to comment Share on other sites More sharing options...
Jonny Posted September 18, 2007 Share Posted September 18, 2007 Fluid passing the seals most probably, not sure if you have a Lamberts Brake & Clutch down there. Check the yellow pages for them, onto it as, cheap and good quality. Only one i know of though is in whangarei. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted September 18, 2007 Share Posted September 18, 2007 Get under the dash and peel back the rubber boot where the actuating rod passes through the firewall. If there is fluid there then your dignisis will be correct and a stainless sleeve might be in order - but please check the price of a new M/S with your Fiat agent first. The last Fiat brake parts I priced were ridiculously cheap Quote Link to comment Share on other sites More sharing options...
FIAT Posted September 20, 2007 Share Posted September 20, 2007 Brand new Fiat 124 masters are avaiable and stupid cheap, like $50 Quote Link to comment Share on other sites More sharing options...
Unclejake Posted September 20, 2007 Share Posted September 20, 2007 Brand new Fiat 124 masters are avaiable and stupid cheap, like $50 Quote Link to comment Share on other sites More sharing options...
Testament Posted September 21, 2007 Share Posted September 21, 2007 Brand new Fiat 124 masters are avaiable and stupid cheap, like $50 Yeah I had to replace mine a while back, think I got it from euroitalian on the shore, but it shouldn't be too hard to find. Unos probably use the same part Quote Link to comment Share on other sites More sharing options...
nzsubbie Posted September 22, 2007 Share Posted September 22, 2007 i had that prob car failed wof coz of that. i did all those things even had it rebuilt. the last thing i did was adjust the pedal up and ive had no complaints so far. it just took that xtra travel up Quote Link to comment Share on other sites More sharing options...
