Exhaust too low to ground: options?!
might_e_mowse
I got a 3" exhaust put on my gx71 nd at the lowest part sits approx 50mm from the ground and scrapes like a bitch, every speed bump, and even when the road curvature is too much.
I can only load the car up to 3 people max which really sucks so what can i do to fix/help the problem.
after havin a look underneath, the exhaust from the floor pan is anywhere between 3-5cm at parts and could probably be raised a little but im not too keen to fork out more $$ to almost rebuild it.
Can i put a metal sheet or somethin similar underneath to protect it??
Any other ideas? :rolleyes:
PS raising the car is option F
