dylan Posted July 23, 2007 Share Posted July 23, 2007 its probably been asked many times but...... how does it work +35,-20 etc Quote Link to comment Share on other sites More sharing options...
Mike-e Posted July 23, 2007 Share Posted July 23, 2007 nomination for most unlikely to use search function Quote Link to comment Share on other sites More sharing options...
Requiemk Posted July 23, 2007 Share Posted July 23, 2007 http://www.oldschool.co.nz/phpbb/viewtopic.php?t=9958 To measure the offset of the wheels - lay the wheel face up on flat ground. Measure from ground to the hub mounting face (call this A), then flip over and do the same (call this B, make sure this is still to the same mounting face). Add A and B together and divide in half (call this C). The difference between C and A is your offset. If A is bigger than C its positive, C bigger than A is neative offset. Having tyres on makes no difference to the measurements as they wil bulge the same on both sides.Most older RWD's are around 20-25P, FWD is generally 35P or more. More positive offset than factory and the wheels are likely to hit your struts. Less positive or even negaive offset usually gives guard clearance problems. Callum Quote Link to comment Share on other sites More sharing options...
dylan Posted July 23, 2007 Author Share Posted July 23, 2007 nomination for most unlikely to use search function i hate that fuckin search thing Quote Link to comment Share on other sites More sharing options...
dylan Posted July 23, 2007 Author Share Posted July 23, 2007 http://www.oldschool.co.nz/phpbb/viewtopic.php?t=9958To measure the offset of the wheels - lay the wheel face up on flat ground. Measure from ground to the hub mounting face (call this A), then flip over and do the same (call this B, make sure this is still to the same mounting face). Add A and B together and divide in half (call this C). The difference between C and A is your offset. If A is bigger than C its positive, C bigger than A is neative offset. Having tyres on makes no difference to the measurements as they wil bulge the same on both sides.Most older RWD's are around 20-25P, FWD is generally 35P or more. More positive offset than factory and the wheels are likely to hit your struts. Less positive or even negaive offset usually gives guard clearance problems. Callum cheers Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 23, 2007 Share Posted July 23, 2007 //oldschool.co.nz/phpbb/viewtopic.php?t=6781 Quote Link to comment Share on other sites More sharing options...
