Roman Posted June 5, 2007 Share Posted June 5, 2007 Yeah I was wondering if someone was going to hit me up about that when I posted it. Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted June 5, 2007 Share Posted June 5, 2007 Yeah Nismo capri is onto it. Make it turbulent to make the flow stick around bends. Used on aircraft , golf balls and all sorts of things. Whether turbulence is a benefit or not depends on the fluid velocity though. I'm not sure how the flow velocity through head ports compares. Someone with a bit of time should look up Reynolds Numbers for ducts, ports etc and see if they find some charts. I have and the maths is nutso! Anyway, equipment wise an air grinder and a decent sized compressor. My die grinder was a lot thristier than my spray gun. a 2.5hp, 50 litre isn't big enough. You'd have to keep stoping and the compressor would be charging all day. I'm pretty sure i've seen long reach grinders on TM too. I love my electric grinder Quote Link to comment Share on other sites More sharing options...
