Guest 4age_starlet Posted May 11, 2007 Share Posted May 11, 2007 hey im looking for a stronger diff for my starlet as ill be runing a 4agte very soon is there anything the bolts stright in? i dont realy wnat to go to a hilux one im willing to spend around 500 at this point of time Quote Link to comment Share on other sites More sharing options...
durty Posted May 11, 2007 Share Posted May 11, 2007 ae86 diff, need fwd stz rims tho cos will make them stick out otherwise Quote Link to comment Share on other sites More sharing options...
l1ttle_d3vil Posted May 12, 2007 Share Posted May 12, 2007 ae86 diff wont bolt straight in, you need to change the mounts as with a hilux diff. ae86 diff won't need shortening aslong as you run fwd offset mags, same goes for the early model hilux diffs. so no differences there, only difference between them is the price and strength: ae86 diffs sell for around $700 with an open diff head, if you want a diff with an LSD head you'll be paying over $1k probably unless you hunt around for ages. you can pick hilux diffs up for about $200 with open diff heads, and another $200 will get you an LSD unit to bolt in. a 4agte will blow a ae86 diff head to pieces relatively easy, a hilux diff will last forever. so for half the price and twice the strength, i'd save up and get a hilux diff...you wont get anything that'll handle a 4agte and bolt in for under $500. Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted May 13, 2007 Share Posted May 13, 2007 im have modiges on with flears on. i could go about 15mm on each side wider would any hilux diff fit that? Quote Link to comment Share on other sites More sharing options...
htwn-escort-boy Posted May 13, 2007 Share Posted May 13, 2007 mates got a kp startlet with 4age, he is running a TRD lsd in it, ill be well over the 500 mark but id say it will be well worth it, Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 13, 2007 Share Posted May 13, 2007 mates got a kp startlet with 4age, he is running a TRD lsd in it, ill be well over the 500 mark but id say it will be well worth it, is that on an ae86 diff? they're gay Ive broke axles with a stock bluetop, depends how you drive but I'd go straight to hilux get it shortened do it once do it properly etc. Then you can keep some dish on your rims Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted May 13, 2007 Share Posted May 13, 2007 i think i am going to got with the hilux up grade what hilux diff best to use? Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted May 13, 2007 Share Posted May 13, 2007 i can get a 85 out of a hilux they want 500 is that about right? Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 14, 2007 Share Posted May 14, 2007 If its LSD then its an ok price. Quote Link to comment Share on other sites More sharing options...
mikuni Posted May 14, 2007 Share Posted May 14, 2007 i can get a 85 out of a hilux they want 500 is that about right? Measure it up man. Make sure its going to be an easy fit and that it doesn't need shortening or anything along those lines. That seems a little steep if its open, but at the end of the day, they are only worth what people are willing to pay and it seems everyone is after them at the moment. You can buy an LSD from an appropriate series diff and stick that in later when funds allow. Also, I see you are going to be running modgies. I guess these will be around 14" so you'd want to double check just to make sure they fit over the drums of the diff. I can't see it being a problem, but 13's might introduce some issues. Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted May 14, 2007 Share Posted May 14, 2007 they are 13inch modiges Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted May 16, 2007 Share Posted May 16, 2007 bump im still cant find a good diff upgrade was going to go with t series but it still to wide and i dont want to change wheels. Quote Link to comment Share on other sites More sharing options...
CUL8R Posted May 17, 2007 Share Posted May 17, 2007 You could always get the diff shortened ... Cheers,Chris Quote Link to comment Share on other sites More sharing options...
Gaz Posted May 17, 2007 Share Posted May 17, 2007 Jus use what youve got for now.. If ya wanna change ya might aswell go hilux and FWD offset rims.. Lenso RS5's would be macking.. But just run standard for now.. at least till after the show. Quote Link to comment Share on other sites More sharing options...
Guest 4age_starlet Posted May 17, 2007 Share Posted May 17, 2007 yea thats what ill think ill do. Quote Link to comment Share on other sites More sharing options...
