Guest WESTCORT Posted April 1, 2007 Share Posted April 1, 2007 ok so 2 of my 3 plugs had hole sand leaked water. i replaced the 1 on the side of the block but when it came to the one at the bellhousing end i ran into trouble. i got a 48mm plug and hammered it in, seemed to be sweet. filled it up with water and there was a very slow water leak. is 48mm the right size? ive tried heaps today... 1 7/8 was too small 1 15/16 was too big and 48mm seemed to go in nice but i still got a water leak, but its quite small. so i pulled the 48mm plug outand put shitloads of instant gasket rubber shit thats rated to 270 degrees and hammered the plug back in. so it didnt leak this time but thats what i expected because of the gasket shit. what i want to know is what size everyone else used and will this gasket shit work or is it gonna get blown out from pressure inside the engine. cheers Quote Link to comment Share on other sites More sharing options...
RT Posted April 1, 2007 Share Posted April 1, 2007 you shouldn't use gasket sealer.. you should use 'shlack' (sp) a thick guey paste made out of beetles. (not kidding) available from any repco etc Quote Link to comment Share on other sites More sharing options...
Ogre Posted April 1, 2007 Share Posted April 1, 2007 shlack is awsome shit, fully recommend that! Only need abit.Tis truly made from mashed beetles. Quote Link to comment Share on other sites More sharing options...
84_S12 Posted April 1, 2007 Share Posted April 1, 2007 Tis "Shellac" like Steve Albini's band So yeah, either way = mashed beatles Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted April 1, 2007 Share Posted April 1, 2007 so if get this magic shlak shit then dump it on the inside and outside, i should be sweet? not goan blow the shlak and give me water runnin out the bellhousin agen? haha Quote Link to comment Share on other sites More sharing options...
Ogre Posted April 1, 2007 Share Posted April 1, 2007 needs to be nice and dry and clean with no oil/grease etc for the shellac to work properly.Need to let it dry too.Tis some strong shit, smells great too. Quote Link to comment Share on other sites More sharing options...
RT Posted April 1, 2007 Share Posted April 1, 2007 you have to paste the shlak around the outer rim of the frost plug before you hammer it in. coating some around the outside won't cut it. Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted April 1, 2007 Share Posted April 1, 2007 ok cool, its all clean as thru there since its all be freshly rebuilt, would lick it no worries etc. so is this shit sort of like a putty? or does it have a rubbery element to it? Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 1, 2007 Share Posted April 1, 2007 Sticky brown shit, but it works fucking well! AFAIK your pinto shouldn't take a 48mm plug man as it should be imperial Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted April 1, 2007 Share Posted April 1, 2007 thats what i thought about the 48mm plug BUT my cortina block i got here has a big 48 stamped on its plug. also a 1 and 7/8 wont fit cause its too small and slides in wayyy to easy, and a 1 and 15/16 is too big and wont go in at all. talked to a few different repcos today cause they all say different shit and nobody had anything between a 7/8 and a 15/16. so i duno eh, will go see john at glendene reco tomorrow maybe. the 48mm fits in quite tight, but theres still a real real small leak. so im guessing this shlak shizz will stop that. how do i apply it? do i press the cap in and then paste it on the outside? or load up the round hole with it and some on the cap and hammer it in.. so hard figuring this shit out when its not exactly a common place problem Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 1, 2007 Share Posted April 1, 2007 Just brush it on the outer edge (where it contacts the block) of the plug before you fit it. And use a socket or something to hammer it in square rather than just tapping around the edge Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted April 1, 2007 Share Posted April 1, 2007 ok sweet, have been using a socket but its hard with the engine in the engine bay to get it perfectly square. might go see a hydraulics place tomorrow aswell and get one thats between 7/8 and 15/16. aparently hydralic places carry heaps of them in all sorts of sizes. cheers for the help so far guys, much appreciated when you go nuts during the day trying to make shit work and it never works out! Quote Link to comment Share on other sites More sharing options...
84_S12 Posted April 1, 2007 Share Posted April 1, 2007 48mm is as close as you'd get to in between the metric sizes you've given I think. 1 and 7/8" is 47.6mm and 1 and 15/16" is 49.2mm Unless you can get them down to 1/64" tolerances in which case you'll want 1 and 57/64" or 58/64" Fuck not being able to sleep and being bored enough to do stupid imperial conversions Quote Link to comment Share on other sites More sharing options...
RT Posted April 3, 2007 Share Posted April 3, 2007 use a block of wood and a rubber mallet. Smacking metal on the block with a metal hammer could cause stress fractures.. Quote Link to comment Share on other sites More sharing options...
