danger Posted March 22, 2007 Share Posted March 22, 2007 Anyone know how to do this shit/ what materials cost etc? Wanna make a small detailed item and want something similar to abs plastic strength. Quote Link to comment Share on other sites More sharing options...
danger Posted March 22, 2007 Author Share Posted March 22, 2007 could nu-tech be used for same kind of thing? Quote Link to comment Share on other sites More sharing options...
Mike-e Posted March 22, 2007 Share Posted March 22, 2007 nu-tech can be used for everything so unhelpful. Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 22, 2007 Share Posted March 22, 2007 My Mrs has done it at uni. Say's it all depends on use's sizes etc. But to make a one off you could do a silicon mould. Need, Silicon, make a hard model out of wood or metal. Silicon mould over the metal then cut the mould inhalf and inject with plastic. The plastic is cheap. The silicon expensive. Something the size of a computer mouse you could do for under 100$ depending. Differant types of silicon for differant things. Cheap non see through silicon you might stuff up more times in the mnaking as you cant see air bubbles. The more expensive clear stuff is prob better to use. Once the silicon mould thing is made its pretty cheap to make heaps of plastic model's. Hope that helps somewhat. Gaz Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 22, 2007 Share Posted March 22, 2007 You can use bog or nutec to make the hard copy. Quote Link to comment Share on other sites More sharing options...
danger Posted March 23, 2007 Author Share Posted March 23, 2007 Cheers! Quote Link to comment Share on other sites More sharing options...
