danger Posted January 29, 2007 Share Posted January 29, 2007 I'm not to sharp on this kind of stuff, can anyone tell me what ratio I should go for for a hilux LSD in a 13BT/S5 5speed ute with 4link and atleast 15x10's on the rear? I wanna drag it. Any advice appreciated Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 29, 2007 Share Posted January 29, 2007 IMO: 5:1-ish. most rotary stuff seems to run near these ratios, esp for drag cars (you'll be running a large sidewall for increased traction... low tyre pressures.... blah blah blah) so 5:1 or lower would be the go. a common rotary ratio is around 4.6:1, these go mint with most stuff, so a lower ratio with the larger rear wheel/tyre combo giving a bigger rolling circumference Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 30, 2007 Share Posted January 30, 2007 You could calcualte it to get a near perfect diff for the 400m with the power of your car, weight of car, wheel size, box ratio etc. Quote Link to comment Share on other sites More sharing options...
RT Posted January 30, 2007 Share Posted January 30, 2007 you can download a diff ratio calculator off our website: http://www.retrotech.co.nz/tech.html Quote Link to comment Share on other sites More sharing options...
danger Posted January 30, 2007 Author Share Posted January 30, 2007 Cheers guys, Its kind of difficult to gauge as I'm building it on the cheap utilising any bargains that come along, I wanna build the chassis first so I think I'll just go hunt down a diff housing at this stage so I can get onto the 4link. Are all hilux diff heads universal? Can I just go get a cheap hiace housing and get a good lsd unit to fit it later? Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 30, 2007 Share Posted January 30, 2007 Can I just go get a cheap hiace housing and get a good lsd unit to fit it later? Nope. There are a few differant ones. I dunno how to tell but id def do some google homework first. I have a hiace housing that doesnt fit my hilux LSD head. I also have one that does... go figure! Quote Link to comment Share on other sites More sharing options...
danger Posted January 30, 2007 Author Share Posted January 30, 2007 http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Ford/Engines-drive-trains/auction-86161167.htm Reckon this would be too heavy? What are they like for finding parts for? Quote Link to comment Share on other sites More sharing options...
mikuni Posted January 30, 2007 Share Posted January 30, 2007 Are all hilux diff heads universal? Can I just go get a cheap hiace housing and get a good lsd unit to fit it later? Yeah, google toyota diff codes. I've never bothered to look it up but there are codes for the diff, 'f' for example and all the heads with fit into that diff. Then there are certain codes stating if if it is lsd etc. Hiaces, crowns, hiluxs, and even some cressidas and supras may all have a suitable diff so that will help you come across one for cheap. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 30, 2007 Share Posted January 30, 2007 go for one that'll fit hilux 4x4 diff heads as they'll be easier to find in the lower ratios that you'll require Quote Link to comment Share on other sites More sharing options...
Gaz Posted January 30, 2007 Share Posted January 30, 2007 http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Ford/Engines-drive-trains/auction-86161167.htmReckon this would be too heavy? What are they like for finding parts for? Wouldnt be tooo much heavier than a hilux. Quote Link to comment Share on other sites More sharing options...
