Guest kornstar Posted January 15, 2007 Share Posted January 15, 2007 Does any one no if a morris 1300 engine will bolt into a 75 clubman? Or even if this is a good conversion? I have been offerd 2 for 500, both in reasonable condition, one worked a fair bit. The other standard. Any ideas? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted January 15, 2007 Share Posted January 15, 2007 I'm still new to these, but I guess you mean the A series Morris engine? i.e 1275? If so yes, bolt straight in afaik (will be doing mine soon) Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 15, 2007 Share Posted January 15, 2007 I'm still new to these, but I guess you mean the A series Morris engine? i.e 1275?If so yes, bolt straight in afaik (will be doing mine soon) hmmm 1300 morris engine = 1275? cool. Not sure either. I no what engine no. it should be to be a 1275... i couldnt see the no's on the two i have inmind, i coulndt reach them. fully noob on small engines... Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted January 15, 2007 Share Posted January 15, 2007 If it looks like a mini engine, then its A series Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 15, 2007 Share Posted January 15, 2007 i took pics on my phone.... these are the 1300 engines out of 1300 morris Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted January 15, 2007 Share Posted January 15, 2007 If the engines are in good cond then do it. I've been looking around for a cheap morris 1300 for exactly that reason-to steal its engine. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 15, 2007 Share Posted January 15, 2007 if the output shafts are the same style as yours on the diff then piece of pis if not, have to change to your gearbox assembly. make sure your radiator's not blocked. they make alot more heat! easiest way to tell if it's a 1275 is by the thermostat end of the head. it's quite different, juts out more... alternatively, look at the engine number tag. first two digits denote the capacity. 84 = 849cc 99 = 998 10 = 1098 12 = 1275 chur Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 15, 2007 Share Posted January 15, 2007 new radiator will be on the way. Yeah i no the no.s for the engine size etc just couldnt see them/didnt have any. How will i no if the out put shafts are the same with out pulling mine apart? So a morris 1300 is a 1275? $500 for two seems good then. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 15, 2007 Share Posted January 15, 2007 just look at the joints on the end of them. can see etc. post a pic if you're confused.... 1300s usually runa rubbercross setup. I'd almost put money on yours having pot style CV's form the pic of the second one I'd say that'd be the saem as yours.... Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted January 15, 2007 Share Posted January 15, 2007 Mines pot type so yours should be, as we're only a year apart Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted January 15, 2007 Share Posted January 15, 2007 Hey Cam. Your the man with all the mini knowledge! If you know anybody who sell rubbercrosses or the nylon ones cheap let me know. Cheers Were the two engines you've been offered from a recently running car? Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 15, 2007 Share Posted January 15, 2007 no, Been there for a while by the looks. old as guy with HEAPS of old english stuff. Said if they were any problems, or they were fuct hed sort me out with cashback etc. Should be good tho i hope. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 15, 2007 Share Posted January 15, 2007 do what you can to change to pot type, or better still, cooper style steel universals.. rubber crosses fuck out all the time, esp with a bit of power behind them! kornstar: easy way to tell, if they haven't got the pots still on the output shafts (common practice.easy as pie to pop them out rather than ruin a good cv joint) is that rubber cross style output shafts have a lot more protruding, a coarser spline, lack the circlip which secures the pot joint on, about an inch in from the end, and have thread on the end (the yokes are held on by these) chur Quote Link to comment Share on other sites More sharing options...
CUL8R Posted January 15, 2007 Share Posted January 15, 2007 @Chrome GT, had this one on my watchlist for a while too... Think its just what you are after.... http://www.trademe.co.nz/Trade-Me-Motor ... 264918.htm Could be wrong but it looks like it has a GT grille too Cheers,Chris Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 15, 2007 Share Posted January 15, 2007 jsut has a 1300 badge. the grilles on gts are same as others AFAIK, save for the badge.. hah Quote Link to comment Share on other sites More sharing options...
CUL8R Posted January 15, 2007 Share Posted January 15, 2007 My bad, thought the GT's had that line through them like that but the normal ones didnt Oh well guess not then Cheers,Chris Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted July 6, 2007 Share Posted July 6, 2007 Old topic however thought I should contribute by providing a link to my project where i have done the 1300 into a mini thing. I've tried to cover all the differences so the project page can be used as a guide http://www.oldschool.co.nz/phpbb/viewto ... =1971+mini Quote Link to comment Share on other sites More sharing options...
davidian Posted July 6, 2007 Share Posted July 6, 2007 daym@kornstar, back up in it Quote Link to comment Share on other sites More sharing options...
