Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 Trying to remove a bolt out of the engine stabilser arm, got one out piece a piss but cant get this fucker out, any ideas? oh and wrecking the bolt it not an option. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted January 12, 2007 Share Posted January 12, 2007 I assume you have loaded it with CRC? Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 yup, the nut came off easy as, and i can turn the bolt no problem, just cant pull it out. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted January 12, 2007 Share Posted January 12, 2007 Maybe have a dig at it with a screw driver or something??? Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 tried that aswell! Quote Link to comment Share on other sites More sharing options...
Muzzie Posted January 12, 2007 Share Posted January 12, 2007 tried that aswell! Put the nut on underneath a couple turns and gently knock it with a hammer. When it gets up to the thread you'll probably be able to wind it out with a socket/spanner/fingers stz Quote Link to comment Share on other sites More sharing options...
dylan Posted January 12, 2007 Share Posted January 12, 2007 hit it from the bottom with a rubber hammer shouldnt wreck the thread Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted January 12, 2007 Share Posted January 12, 2007 hit it from the bottom with a rubber hammer shouldnt wreck the thread Or a bit of wood. Or pry the threaded side with wood. Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 no room for a hammer there. Tried banging it out. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted January 12, 2007 Share Posted January 12, 2007 Harden up and cut it!! Quote Link to comment Share on other sites More sharing options...
dylan Posted January 12, 2007 Share Posted January 12, 2007 hmm what about using somthing like a long screwdriver and hitting that with a hammer if theres more space further down the only problem is u could really fuck the bolt up Quote Link to comment Share on other sites More sharing options...
dylan Posted January 12, 2007 Share Posted January 12, 2007 Harden up and cut it!! haha yea and just go buy a new bloody bolt Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 yeah might have to fuck it, damn. I need to drive around tho and MSL is closed so cant get the right bolt to replace untill monday. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted January 12, 2007 Share Posted January 12, 2007 Got a welder?! Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 have access to one, but not untill monday... y? Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted January 12, 2007 Share Posted January 12, 2007 Not really much of an advantage then, weld something onto the head so you can pull it easier. Quote Link to comment Share on other sites More sharing options...
Raizer Posted January 12, 2007 Share Posted January 12, 2007 Vise grips, wriggle and pull Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 Vise grips, wriggle and pull sweet should work. I got do my monthly saturday shift 2moro so ill grab some then, didnt have any in the van. Cheers Quote Link to comment Share on other sites More sharing options...
Mr Revhead Posted January 12, 2007 Share Posted January 12, 2007 yeah prob just jammed from tension on the support try prying that a bit to see if it loosens it up Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 12, 2007 Share Posted January 12, 2007 i tried loosening the tension and hitting/prying it through but no go. Hopefull with some decent grip it will be good Quote Link to comment Share on other sites More sharing options...
