Gaz Posted October 14, 2006 Share Posted October 14, 2006 OK dokie. Got my hiace dual wheel axles and diff head. (6stud) Got my hilux housing with axles (6stud) The axles from the hilux wont fit the head from the hiace. I had been told they would. is there differant splines for differant models? I want to buy an LSD head but need to know what to look for.. or what vehicle etc. Also the actual head from the hiace doesnt wanna fit in the housing from the hilux. Is it usually a tight fit for the hilux diffs to go in? On a good note. It looks like the differance in length is determined by the axles not the housing. Which means... I dont have to shorten my housing at all. I can get the right width (1350, or actually 1340 if i wanted) using the hiace axles with the hilux housing... If I can get them in.. So yeah, tell me about hilux/hiace splines and heads. Go.. cheers Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted October 14, 2006 Share Posted October 14, 2006 DELETED Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 14, 2006 Author Share Posted October 14, 2006 Im not sure what code it is. Might try find some pics or some way of identifing on google. I supose I half assumed itd fit as my mate has a hilux LSD in his hiace. The guy I brought it off did say a hilux head will fit tho. Wonder if there were any hiace LSD heads then? Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted October 15, 2006 Share Posted October 15, 2006 Easiest way would be measure across the crownwheel - should be 8". If its not, its not a G code. Would think it should fit. Aren't all the axles 31 spline? Count the splines on the axles and on the diff too. http://www.toysport.com/Technical%20Information/Toyota%20Differentials%20Identifications.htm Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 15, 2006 Author Share Posted October 15, 2006 Wicked ill measure tommorow. Ill also put pics up of where it is catching meaning it wont go in. Also brought a hilux housing and LSD hwead out of a 1993 2500 deisel RWD hilux today. $200 so im happy especially since it came with a spare LSD head.. Pity the short hiace axles wont go into the hilux LSD as they are to small/diff flange.. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 15, 2006 Author Share Posted October 15, 2006 Also those diff codes are all the wazoo. I have seen them many places all over the net in last few days... So when buying this hilux diff today I checked the tags.. The 4 digits the website talks of to tell ratio etc is only 3 digits on my tag... hence no number to tell me if the head was LSD or not. Got it home and pulled head out and it is LSD!!! Wouldnt trust everything on the net Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 16, 2006 Author Share Posted October 16, 2006 this what dont fit. Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 16, 2006 Author Share Posted October 16, 2006 Just counted the spline. 30 on both but the hiace one is smaller dia.... Fucking Toyota.! Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted October 24, 2006 Share Posted October 24, 2006 weird... i have run a hiace head in my hilux housing and currently run a hilux from a 4wd in it. your other one must be somethin different???? (woldnt happen to have a spare 3.9 for sale?) Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 24, 2006 Author Share Posted October 24, 2006 Yeap I got a 3.9.... but its the one that doesnt wanna fit in my 4wd housing so prob no use. Am going to try and swapsies on the spiders somehow. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted November 2, 2006 Share Posted November 2, 2006 what measurements of the crown wheel did u get? Quote Link to comment Share on other sites More sharing options...
