Gaz Posted October 6, 2006 Author Share Posted October 6, 2006 Brought and made one of them jaycar DIY kits tonight. Will find an o2 sensor and set it up for now. See how that goes. The guage can be calibrated to certain sensors so in my eyes makes it better than the guages you buy. + is a fraction of the price. Quote Link to comment Share on other sites More sharing options...
FLAWLES Posted October 6, 2006 Share Posted October 6, 2006 most o2 sensors are generic but comadore ones are good to use......... ive destroyed many on my gtz ( may she RIP ) i have a old o2 sensor bracket some were that you can have for 4 free i just have to find it Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 6, 2006 Author Share Posted October 6, 2006 Oh true. Im bidding on a nissan one at the mo. $5 no reserve. Im just going to drill/tap it into the dump pipe off the manifold. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted October 7, 2006 Share Posted October 7, 2006 i have a few if you want one meths, jusg go buy a m18x1.5 half nut and weld into the exhaust after the collector. you want a heated o2 senser (4 wire) becose a non heated one will not give accurate readings unless it is at the rite tempurature. and you know that thing you just made it just a volt meter- a good multi meter will do the same as the o2 senser just gives a voltage reading between 0 and 1, lean to rich. does it have a read out or leds? pics? another thing is to do a power run on dyno with a a/f map built into the chart. gud luck Quote Link to comment Share on other sites More sharing options...
lowlancer Posted October 27, 2006 Share Posted October 27, 2006 Bumpage Need an o2 sensor for ma mo fuckin car. Should I just replace with standard, or get a wideband? My ecu only allows for a single wire for o2...If that makes sense Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted October 27, 2006 Share Posted October 27, 2006 multi wire sensers are just heated. still only have one signal wire. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted October 27, 2006 Share Posted October 27, 2006 Sweet So where do I get said wideband cunt fro? Quote Link to comment Share on other sites More sharing options...
Gaz Posted October 27, 2006 Author Share Posted October 27, 2006 You can get widebands from NZEFI. Google them. Bout $700 all up. Quote Link to comment Share on other sites More sharing options...
