Gaz Posted June 26, 2006 Share Posted June 26, 2006 Big brake meaning the capri vented disks? They are 22mm thick so you need a spacer for use with AP calipers on them. Quote Link to comment Share on other sites More sharing options...
OSC Posted June 27, 2006 Share Posted June 27, 2006 yeah thats the one the capri vented disc i know i need spacers the stub axles are also meant to be bigger and better on thems. Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 27, 2006 Share Posted June 27, 2006 capri struts are better, thats why everyone makes them coilovers unlike crappy escort struts Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 27, 2006 Author Share Posted June 27, 2006 capri struts are better, thats why everyone makes them coilovers unlike crappy escort struts I have two sets of escort coilovers. There is nothing wromng with them. Escort struts kinda suck for rally as the stub axle can crack and escort ones are not replaceable. That is why when you turn them into coil overs you weld the sleeve right to the bottom strengthening the rear of the stub axle. For anything apart from doing huge jumps they are sweet as. Quote Link to comment Share on other sites More sharing options...
OSC Posted June 28, 2006 Share Posted June 28, 2006 true. i jst want a vented disc front leg so i thort id get mk1 capri gt except that to fit them into a mk2 escort i need a mk1 steering rack as the tie rod end size is different and mk1 capri is different thread size to mk2 escort but yeah um has anybody got a right hand side WAGON tail light im still looking. oh and does anybody know how to contact ford playhard racing in the bop because my contact numbers dont work anymore and i need some more parts. oh yeah and does anybody have the bits to convert a square light mk2 escort into a round light thanks pm me if you have any of the bits thanks old skool for life Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 28, 2006 Author Share Posted June 28, 2006 Arnt the vented capri disks off the 2.8 injected capris only? here are new ones for a reasonable price new. http://www.palmside.co.nz/parts.asp?mak ... ory=BRAKES Why bother tho. Do you have brake fade problems? Quote Link to comment Share on other sites More sharing options...
OSC Posted June 28, 2006 Share Posted June 28, 2006 no but i want heaps better stopping then standard mk2 and slowing from 220 repeatedly will cause them to fade so vented would be better and capri + ap calipers is bolt on so easy to do conversion i cant be assed spending alot of money or mucking around making stuff fit Quote Link to comment Share on other sites More sharing options...
peteretep Posted June 28, 2006 Share Posted June 28, 2006 dont ap calipers need spacers to fit vented disks? Quote Link to comment Share on other sites More sharing options...
OSC Posted June 28, 2006 Share Posted June 28, 2006 yep sure do but they are an off the shelf part so meh wateva brakes i have im going to pull to bits and rebuild anyway last thing i wanna do is put it into a barrier from lack of stopping power Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 28, 2006 Share Posted June 28, 2006 How about volvo 4pots? Quote Link to comment Share on other sites More sharing options...
OSC Posted June 28, 2006 Share Posted June 28, 2006 do they bolt onto to escort or capri struts??? what discs do they take vented or solid? Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 28, 2006 Share Posted June 28, 2006 Mount needs to be slotted, think you can get away with capri disks, il post some pics + info soon Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 28, 2006 Author Share Posted June 28, 2006 What will you be building the car for that you need to slow from 220ks? The volvo calipers can be made to bolt on but why bother when price is same as AP and the APs do bolt straight on. Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 28, 2006 Share Posted June 28, 2006 The slotings easy enough to do, basicly just redrill The volvo calipers can be made to bolt on but why bother when price is same as AP and the APs do bolt straight on. Whats a pair of APs worth? I havnt seen many pairs of them for $50 or under, also how about the fact the volvos have larger pistons? Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 28, 2006 Share Posted June 28, 2006 You can use 2.8 capri disks, but the best 1s to use are e30 bmw 323i disks. They just need a lil machining. Thats 2mil from the hub and 2.5 from the face. And from memory 2mil off overall diamiter. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 28, 2006 Author Share Posted June 28, 2006 The volvo calipers can be made to bolt on but why bother when price is same as AP and the APs do bolt straight on. Whats a pair of APs worth? I havnt seen many pairs of them for $50 or under, also how about the fact the volvos have larger pistons? I myself think the slotting is dodgy but hey, what do i know. The AP calipers are the PERFECT calipers for the fact that the volume of oil is the same as standard escort calipers. Piston size is irrelevant. Pad size/piston distribution is more to the point. Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 28, 2006 Share Posted June 28, 2006 The volvo ones arnt much bigger (oil volume wise), have a bigger pad face and if the slotting so dodgey they wouldent have been used on race/rally escorts/cortinas in Aus for the past 20 years. But either way there both good calipers. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 28, 2006 Author Share Posted June 28, 2006 Whats the oil volumn of the Volvo ones and piston size? Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 28, 2006 Share Posted June 28, 2006 Depends if there the girling, ata or volvo brand ones, will measure the 1s we've got next time i got down the yard, cant be stuffed googling it. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted July 5, 2006 Share Posted July 5, 2006 i used volvos on the mk2 with toyota disc rotors, ya only have to slot em about 2-3 mm each hole so its f-all . mine had a mk3 corty master cyl and no booster and stopped real hard. only cost about $300 for entire conversion. Quote Link to comment Share on other sites More sharing options...
