ThePog Posted June 28, 2006 Share Posted June 28, 2006 My Fiat twincam Ladawagon has been playing up - dying at low revs then ok for a few k's then playing up again. Seems to be worse immediately after I give it some beans. Someone else has suggested resetting the carby float level as it might be fuel starvation. Haynes manual is very sketchy on the details of doing this - anyone with some advice? Carb is a twin choke downdraft weber 34DMS. Have checked all the potential electrical problems - it all checks out fine..... Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 28, 2006 Share Posted June 28, 2006 Sounds similar to my old cortina problem. Will find you a link and let you decide if it is the same. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 28, 2006 Share Posted June 28, 2006 After reading thruthem they may not be of any help but here they are anywho. First carb prob/carb //oldschool.co.nz/phpbb/viewtopic. ... highlight= Changed carb and new prob //oldschool.co.nz/phpbb/viewtopic. ... highlight= Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 28, 2006 Share Posted June 28, 2006 sounds like crap blocking up something in your carb.. or maybe fuel filter has water in it? Quote Link to comment Share on other sites More sharing options...
ThePog Posted June 29, 2006 Author Share Posted June 29, 2006 I have a spare carb which I might slap on to see if it makes a difference. Thought it was the mechanical fuel pump, so fitted an electric one I had lying around - no difference there. The spare carb has been lying around for a while so might be a bit dodge anyway - suck it and see I spose Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 29, 2006 Share Posted June 29, 2006 Rebuild kits for them are usually pretty cheap. Could do that. Quote Link to comment Share on other sites More sharing options...
