Guest escortpartsnz Posted December 13, 2005 Share Posted December 13, 2005 Hey just after a bit of help, need to work out the ratio of a esky diff have heard you have to count the number of teath on the gear wheel is that right? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 13, 2005 Share Posted December 13, 2005 count the teeth on the crown wheel (biggest gear) and the pinion (gear that drives the crown wheel... then divide the crown wheel by the pinion.... for example.... 33 teeth on crown, 8 on pinion 33/8 = 4.125 = 4.125:1 ratio.... Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 13, 2005 Share Posted December 13, 2005 Or if its still in the car. Hold one drum still. Turn the other drum exactly 10 times. Count the number of times the diff flange turns....(It will be something like 19.4 times) Double this number and divide by ten. Likely ratios are 3.54, 3.77, 3.89, 4.11 (If it's a standard Escort diff, then you can expect it to be 3.89 or 4.11) Quote Link to comment Share on other sites More sharing options...
Defective Posted December 13, 2005 Share Posted December 13, 2005 sorry for the hijack, but how do i tell if my diff's a LSD? i heard something about if you spin one wheel the other one should turn at the same time or something? Quote Link to comment Share on other sites More sharing options...
esky boi Posted December 13, 2005 Share Posted December 13, 2005 Yep thats right, with a normal diff when you spin one wheel the other one will stay still/move only slightly. With an LSD both will turn, and there'll be abit more effort required to turn it too. Quote Link to comment Share on other sites More sharing options...
Defective Posted December 13, 2005 Share Posted December 13, 2005 Yep thats right, with a normal diff when you spin one wheel the other one will stay still/move only slightly. With an LSD both will turn, and there'll be abit more effort required to turn it too. sweet cheers dude Quote Link to comment Share on other sites More sharing options...
RT Posted December 13, 2005 Share Posted December 13, 2005 get a wire brush and clean off the crud until you find the tag that says what ratio it is.. I'm guessing you already tried this? Quote Link to comment Share on other sites More sharing options...
Ned Posted December 13, 2005 Share Posted December 13, 2005 was gonna say that too, most/all diffs will have the ratio stamped on the housing. but then again, it couldve been changed too. Quote Link to comment Share on other sites More sharing options...
Guest escortpartsnz Posted December 13, 2005 Share Posted December 13, 2005 Yea tried that im still trying to get all the shit off it to just un do the bolts what a job Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 13, 2005 Share Posted December 13, 2005 Or if its still in the car.Hold one drum still. Turn the other drum exactly 10 times. Count the number of times the diff flange turns....(It will be something like 19.4 times) Double this number and divide by ten. Likely ratios are 3.54, 3.77, 3.89, 4.11 (If it's a standard Escort diff, then you can expect it to be 3.89 or 4.11) do it that way Quote Link to comment Share on other sites More sharing options...
Guest escortpartsnz Posted December 13, 2005 Share Posted December 13, 2005 I would but its sitting on the floor in my room Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 14, 2005 Share Posted December 14, 2005 count the teeth on the crown wheel (biggest gear) and the pinion (gear that drives the crown wheel...then divide the crown wheel by the pinion.... for example.... 33 teeth on crown, 8 on pinion 33/8 = 4.125 = 4.125:1 ratio.... Well do it this way then Quote Link to comment Share on other sites More sharing options...
