Guest Scheme Posted September 26, 2005 Share Posted September 26, 2005 Mates 4k is knocking like shit, coming from the rocket cover, obviously its a tappet/rocker problem what do you look out for if you take the cover off? Quote Link to comment Share on other sites More sharing options...
v3k Posted September 26, 2005 Share Posted September 26, 2005 mine made a really bad ticking sound before the oil got up there. But a knocking? Like piston slap? Might not be th best omen. Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted September 27, 2005 Share Posted September 27, 2005 heh yeh, its a motor I put in my mates car... he bought it in a rolled and bowled starlet for $100, I told him to give me the whole weekend to take it apart and replace bearings etc, but he knew better and asked me just to do the swap, heh. definately sounds like a knocking noise and gets worse the higher the rpm. Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted September 27, 2005 Share Posted September 27, 2005 could very well be a fucked piston Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 27, 2005 Share Posted September 27, 2005 you put new oil in it? have you set the tappets? is it a knock for a tick sound? does it have power? Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted September 27, 2005 Share Posted September 27, 2005 yea gave it a mobil super oil change, its definately not a ticking sound, its quite a loud knock. The tappet could just be loose as shit, but its not a normal tappet sound I've come across those enough before. Could be a cracked piston, maybe bent pushrod. I'll have to pull the motor apart in the weekend. Just havent come across the problem in a 4k yet. Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted September 27, 2005 Share Posted September 27, 2005 it was a bogan 4k anyway, it was leaking oil out the sump, had a water leak in the thermostat housing gasket and the water pump which I fixed up, it also had moisture in the rocker cover and I warned him about that, but he knows better. I still get paid for putting the motor in so meh, dont really care. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 27, 2005 Share Posted September 27, 2005 mayb a pushrod has come rite out of its seat? Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted September 27, 2005 Share Posted September 27, 2005 Could be, kinda feels like its running on 3. Quote Link to comment Share on other sites More sharing options...
v3k Posted September 27, 2005 Share Posted September 27, 2005 Check spark plugs, I had one die on my mitsi - wondered what the knocking was..... it was it running on 5 Sounds simple, but you'd hate to overlook it Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted September 27, 2005 Share Posted September 27, 2005 plugs replaced on install. Quote Link to comment Share on other sites More sharing options...
anglebox64 Posted September 28, 2005 Share Posted September 28, 2005 yea mate had lifter come away from roker arm and hitting rocker cover but if its realy bad buy buy bottom end big ends make a big knock knock when there stuffed dont over rev it or it will say boo out the side off block or sump best to drian oil and strip down id say few hundy for complete rebuild Quote Link to comment Share on other sites More sharing options...
