Chrome_GT Posted September 7, 2005 Share Posted September 7, 2005 The brake pedal in the mini stays at the normal 'brakes on' position. It won't return back by itself. I have to lift the pedal with my toes to release the brakes Anyone had similar problems before. It happened overnight so I'm thinking something mechanical had broken, slipped loose, or something. -Have checked rear brakes for adjustment, will check fronts. -Have had a quick look under dash at the pedal spring, pretty hard to see but nothing obviously wrong - will check front wheel cylindars when i have the front wheels off -Checked fluid - will check master cylindar but thats the last thing I want to do. - considering bleeding the brakes but i don't really think thats what's wrong. Any suggestions? I need to drive my cheap to run car again. Two weeks of using the Capri everyday is getting costly Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted September 7, 2005 Share Posted September 7, 2005 Will be the master cylinder sticking or broken spring. My booster had a broken spring did the same thing. Quote Link to comment Share on other sites More sharing options...
durty Posted September 7, 2005 Share Posted September 7, 2005 my guess would be broken spring Quote Link to comment Share on other sites More sharing options...
Guest rip Posted September 7, 2005 Share Posted September 7, 2005 From the manual there are a few things but not time tonight to type out but as it was sudden these stand out more try master reservor vent hole in cap blocked with dirt master cylinder by-pass port restriced rear brake shoe pull off springs, broken stretched or loose Cheers Roy Quote Link to comment Share on other sites More sharing options...
Hemi Posted September 8, 2005 Share Posted September 8, 2005 its all been siad haha yea broken springs inside the master cylinder im thinking Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted September 8, 2005 Author Share Posted September 8, 2005 Sweet. Will check all those things. I'll chuck a post up when I have it sorted so ya know what it was.Cheers guys. Quote Link to comment Share on other sites More sharing options...
