drftnmaz Posted September 6, 2005 Share Posted September 6, 2005 whats a off the shelf oxy sensor thats not that expensive. i want to put it in a few of my cars then i can change my digitial air/fuel guage between them for tuning etc... Quote Link to comment Share on other sites More sharing options...
RT Posted September 6, 2005 Share Posted September 6, 2005 I run a autogauge one which was about $100.. and the sender itself was $100. $200 is not much to pay for something that can save your engine! they are also helpful for tunning but only as a rough guide eh. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 6, 2005 Author Share Posted September 6, 2005 hmmm yea i already have a digitial readout guage that i made from jaycar. so i'm just looking for the sender thats cheap so i can put one in each car... yea only a rough guide but i need something for my carby turbo at the mo Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 6, 2005 Share Posted September 6, 2005 ive been thinkin about rigging one up as a tuning aid as dyno time isnt cheap. any oxy sensor hooked up can be read witha volt meter as the voltage will fluctuate as it goes from rich to lean. u just have to figure out which reading is which. reving the engine should give a rich reading or a certain voltage. then you know what voltage a lean reading should give. with a bit of trail and error at idle you can get a handle on the mixture readings while your driving. this is meant to work i havent tried it so its not proven but it sounds correct in theory Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted September 6, 2005 Author Share Posted September 6, 2005 i can post up the typicial reading if you want (volts i mean) cause i have it written down in my kit for my guage. and its easy to work out from there. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 6, 2005 Share Posted September 6, 2005 sweet post away Quote Link to comment Share on other sites More sharing options...
Chrome_GT Posted September 6, 2005 Share Posted September 6, 2005 [/img] A couple bits of info for ya. In this experiment the 14.7:1 was obtained at 0.5volts from the oxygen (lambda) sensor. You can see what voltage to look out for if you want economy (BTE) or Power (BP). I'm not sure if all sensors have the same output voltages. Yeah it does fluctuate too when ya go from rich to lean as SKYCOV said. Quote Link to comment Share on other sites More sharing options...
