RT Posted August 7, 2005 Share Posted August 7, 2005 Ok, 1 peice and 2 peice driveshafts. As far as I know the 1 peice shaft is stronger.. or at least, has one less joint that can break. However, the 2 peice was used because it minimises vibration. It's easier get a true balance from shorter units than longer ones, hence the development of the 2 peice.. I have a 2 peice shaft from factory in my capri. But I have to get it all modified anyway for the new diff and box, should I change to a single peice item or not? Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 7, 2005 Share Posted August 7, 2005 I've read, and been told a lot, that 1 pieces are a lot better, strength wise. Basic physics isn't it. Quote Link to comment Share on other sites More sharing options...
Guest kris Posted August 7, 2005 Share Posted August 7, 2005 single = stronger. That's all there is to it, go single. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted August 7, 2005 Share Posted August 7, 2005 I was told 2 piece makes a bigger vibration! Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted August 8, 2005 Share Posted August 8, 2005 single, thats what ive got ,had no trouble with it easy to service say no more Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted August 10, 2005 Share Posted August 10, 2005 im thinkin the same thing with my cortina,but do they just bolt straight in,i heard they had different splines between the two,is this so? Quote Link to comment Share on other sites More sharing options...
