removing the sump from a 1980 galant
skunkwerx
get a real big hammer and hit the shit outa it.
If that dotn work then use a bigger hammer.
Nah.
You can get the sump off if you choke the motor up.Have to undo the engine mounts and then get a peice off wood behind the sump on that flat sorta peice infront of the gearbox bell housing, then use a trolly jack to jack it up.
Ive never actually taken the sump off b4 without the motor actually being out of the car, but this is how the manuel says you can do it.
Im presuming your car is a RWD galant/sigma.
Good luck
