Guest blown4 Posted June 18, 2005 Share Posted June 18, 2005 put a kent fast road cam(reground to the specs) in my cortina 2ltr ohv today but now it wont fukkin idle,its"cough"auto"cough"and when put in drive it puts out and dies. i done it as per the"haynes manual"so i know the timings ok. ive heard of reground cams being done wrong but its sposed to be a reputable firm. any usefull ideas,im stumped and dont really want to have to redo it.. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted June 18, 2005 Share Posted June 18, 2005 it doing that because you still have the stock torque convertor on the auto. with a warm cam they like to idle abit higher and have a little less vacuum when ya put it in gear the convertor pulls the revs down enough to stall the engine. my cortina was totally undriveable with the stock convertor i put a 3000rpm stall in it gives it a bit of slip down low so the motor can make a bit of power b4 it starts to drive the wheels. best bet 4 u is to put a manual in it Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted June 19, 2005 Share Posted June 19, 2005 i was told it was so mild it wouldnt effect the auto at all,i have the idle as high as it will go,it idles albeit roughly(cam maybe?)but wont idle in drive gotta gas it a bit when going into drive as i take off,not good on the new diff(standard ratio) i drive this car every day and have to go to work tomorrow,goes good on the open road,but "pinks"a bit.adjusting the timing only makes things worse. STRESS FACTOR 10.... Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 19, 2005 Share Posted June 19, 2005 If its pinking then you'll need to retard the timing bro, u tried that? Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted June 19, 2005 Share Posted June 19, 2005 have ya got all the vacuum lines all pluged in and the pcv valve? Quote Link to comment Share on other sites More sharing options...
two_days_late Posted June 22, 2005 Share Posted June 22, 2005 i was under the impression your not meant to change the cams in autos? im sure i read that in the burton catalogue Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted June 23, 2005 Share Posted June 23, 2005 i took it into Tuning and Performance today,they came up with the same answer as me;the cam guys fucked up the grind so now i have to do the fukkin job over again GRRRRRRRRR!! and buy another cam,lucky i havent piad for the bad one so i can still take it back and shove it up their.... Well u get the point. Am i allowed to put the name of the cam guys on here as a warning to others to steer clear?? Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted June 23, 2005 Share Posted June 23, 2005 i dont see why not Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted June 23, 2005 Share Posted June 23, 2005 i am fitting a BRAND NEW cam this weekend so i'll wait till then when its confirmed to be the problem,then i'll let yoose fullas know so you dont get caught out this way.i'd hate to bad rap a business for no reason. i hope its just a one off cock up from these guys,i'd hate to thing this happens often from them. Quote Link to comment Share on other sites More sharing options...
Jerm Posted June 23, 2005 Share Posted June 23, 2005 It might notn be the cam aye.... I was told not to touch the cam in an auto... it causes big probs apparently...? Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted June 24, 2005 Share Posted June 24, 2005 I had a standard cam in the car,the whole engine was stock in fact.When I drove it into the shed it was running fine but the cam had bad wear on it.I put the new(reground)cam in and it run like a big bag of hairy arseholes now(by the way,the rockers were ground as well and buckets made up to fit the valve tips which is spose to be right)but im putting the NEW cam in tomorrow so we'll see what happens,i'll keep yoose posted.... Quote Link to comment Share on other sites More sharing options...
two_days_late Posted June 24, 2005 Share Posted June 24, 2005 might wana have a read of this bro Burtons do not recommend installing a performance camshaft in a vehicle fitted with an automatic gearbox https://www.burtonpower.com/technical/tt_camshaft.html cheers Matt Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted June 24, 2005 Share Posted June 24, 2005 thanx man,good thing im going back to standard then ay Quote Link to comment Share on other sites More sharing options...
two_days_late Posted June 24, 2005 Share Posted June 24, 2005 haha sweet. be better of puttin in a manual! Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 24, 2005 Share Posted June 24, 2005 Yea I reckon aye, would be simple enough to do ... Quote Link to comment Share on other sites More sharing options...
davidian Posted June 25, 2005 Share Posted June 25, 2005 i wonder if RT thought about this cam grind/auto box bizz as well? didnt he say hes thinking about converting to auto ways? Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted June 25, 2005 Share Posted June 25, 2005 well there we have it then,put the new standard cam in today and it runs beoooooty!!So it appears it was a shit grind so as promised....CamCo in rotorua were the wankers who fukked it for me.so they will be getting it back tomorrow and wont be getting any money from me!! Quote Link to comment Share on other sites More sharing options...
Guest blown4 Posted June 25, 2005 Share Posted June 25, 2005 oh and as for the "auto to manual",i prefer the auto at the moment as i travel up north ALOT and prefer the auto as i travel throo Aucks during peak hours if u get wot i mean.. Quote Link to comment Share on other sites More sharing options...
