davidian Posted June 12, 2005 Share Posted June 12, 2005 hoping someone can help.... I put the gearbox and clutch back in the 4wd, and it ran sweet. but on the open road, in 4th and 5th gear if I nail it the engine over-revs and the driveline takes a few seconds to catch up to the revs. on easy acceleration it picks up no prob. also, on a steep gradient it cant handle the load. was coming up the bombays last night and she revved like fuck but hardly got up the mountain any clues? cheers Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 12, 2005 Share Posted June 12, 2005 clutch slipping check the usual things Quote Link to comment Share on other sites More sharing options...
davidian Posted June 12, 2005 Author Share Posted June 12, 2005 fuck chekin the usual things hahaha spent like 4 days on this bastard man. yeah the clutch sounds like its slipping but i just put a new HD clutch plate in there with all the shit so it "should" be ok, but... Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 12, 2005 Share Posted June 12, 2005 hmm, it's releasing completely??? possibly the slave sticking or somehting silly like that.... either way, it sounds like it's definitely the clutch, make sure u sort it before it burns it out completely... Quote Link to comment Share on other sites More sharing options...
davidian Posted June 13, 2005 Author Share Posted June 13, 2005 yeah cheers. anyone ideas? (not cam) Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 13, 2005 Share Posted June 13, 2005 did you sand the flywheel and disk???? ur ment to lol Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 13, 2005 Share Posted June 13, 2005 yeah cheers. anyone ideas? (not cam) rude...... Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted June 13, 2005 Share Posted June 13, 2005 Well, I reckon Cam's right. Undoubtedly clutch slip and it's not unknown for the hydraulic side to stick if the pistons wind up in a different spot. Back off the hydraulic pipe at the slave cyl for a start and see if the clutch arm moves to return. Eddie Quote Link to comment Share on other sites More sharing options...
davidian Posted June 13, 2005 Author Share Posted June 13, 2005 sweet cheers ill try that bugger Quote Link to comment Share on other sites More sharing options...
davidian Posted June 13, 2005 Author Share Posted June 13, 2005 did you sand the flywheel and disk???? ur ment to lol didnt sand but did clean properly Quote Link to comment Share on other sites More sharing options...
esky boi Posted June 14, 2005 Share Posted June 14, 2005 Is it adjusted properly? Quote Link to comment Share on other sites More sharing options...
Guest Steve123 Posted June 14, 2005 Share Posted June 14, 2005 what car and what brand clutch? Quote Link to comment Share on other sites More sharing options...
davidian Posted June 14, 2005 Author Share Posted June 14, 2005 what car and what brand clutch? nissan terrano. umm clutch brand i fogot.. some heavy duty UK made clutch plate (red & blue box) the clutch is in the box perfectly and the hydraulic fluid has been bled and ajdusted. Ill have to check the hydraulic pipe to see if its returning properly. also i have a doubt that there might have been a sligh bit of grease or something on the pressure plate thats making the clutch plate slip cause i used an old one that was in good nick but didnt sand it down, just cleaned it Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 14, 2005 Share Posted June 14, 2005 what car and what brand clutch? nissan terrano. umm clutch brand i fogot.. some heavy duty UK made clutch plate (red & blue box) the clutch is in the box perfectly and the hydraulic fluid has been bled and ajdusted. Ill have to check the hydraulic pipe to see if its returning properly. also i have a doubt that there might have been a sligh bit of grease or something on the pressure plate thats making the clutch plate slip cause i used an old one that was in good nick but didnt sand it down, just cleaned it hah, i'd never do a clutch plate and not the pressure plate, just causes problems, as you're experiencing now Quote Link to comment Share on other sites More sharing options...
davidian Posted June 14, 2005 Author Share Posted June 14, 2005 was too broke after buying a new box bro.... Quote Link to comment Share on other sites More sharing options...
Ned Posted June 15, 2005 Share Posted June 15, 2005 maybe your box is leaking oil...?!? happened to me Quote Link to comment Share on other sites More sharing options...
